Tyre change. I need some help. I30 Coupe GD
Offline EmpiriuS88
    • si Slovenia
      Velenje
Hello.
I am trying to change the front tires with rear ones to even out the wear. But I noticed none of the wrenches fit the screws on Hyundais 16" wheels. So I am wondering what size are the heads on rims. I tried my dads Peugeot 508gt and the wrench doesn't fit. I tried my brothers aftermarket wrench for hes Fiat Brava (2000) with two different headers and it is still too small. Any of you guys know the size????
  • 2014 GD 3 Door Hatch , 1.6 CRDi, manual
Wheel nuts should be 3/4, mine are anyway.
Doesn't your car have the wheel kit/tools under the rear panel in the boot :undecided:
Offline EmpiriuS88
    • si Slovenia
      Velenje
No it doesn't. It has the compressor paste device.
Offline EmpiriuS88
    • si Slovenia
      Velenje
Well I just found this site. So I'm going to the store now, to ask if they got the stuff ;)
:link: Hyundai i30 2016 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
Whats that :confused:
This is what is factory supplied with mine, all the tools to change a wheel.
"compressor paste device."
Same stuff as in our top-end RAV4, where you don't get a spare wheel, just an electronic compressor and some gunk that you squirt into a punctured tyre.
Like that works if you get a tyre shredded :rolleyes:
Bloody cheapskates.
Offline cruiserfied
  • Crooked-H Hero
All factory wheel nuts are 21mm
Offline cruiserfied
  • Crooked-H Hero
3/4 is 19mm
13/16 is close to 21mm
« Last Edit: March 19, 2015, 09:30:21 by cruiserfied »
3/4 is 19mm
You're right, I'm wrong :Pout: I forgot the new wheels had smaller diameter nuts installed to fit the smaller holes :head_butt:
Offline cruiserfied
  • Crooked-H Hero
3/4 is 19mm
I actually thought that when you might have meant your new wheels when you said it. That's why I said "factory" wheels
3/4 is 19mm
I checked the socket I keep in the boot for the rims which had 3/4 on it but plainly forgot they had been changed and when you said they were 21mm I agreed before even thinking about it  :rolleyes: then it dawned on me "I fxxxxd up" :whistler: :D
