Rear wiper blade 2013 I30 UK
Eggman · 12 · 8975
Offline Eggman
      Weston super Mare
  • 2012 i30 1.6 CRDi Blue Drive Active GD
Can somebody point me in the direction of where I can buy a rear wiper for my i30 in the UK please?
Halfords don't seem to stock them and other places only seem to sell the older shape :s
Can't get to dealer too easily.
  • i30 1.6 Crdi
Can you not just buy a rubber insert and cut down to length to save buying the whole unit
That's what I did - from Halfords.
Fiddly to fit - but worth it.
Offline baroudeur
:link: Rear Wiper Blade Fits Hyundai i30 (2007-2013) Hatchback Genuine Rocwood | eBay
They are very good match to the original blades but one advantage is that the squeegee rubber and metal strips can be removed and fitted to the original Hyundai wiper blade frame.  Easiest way is to pop a swinging arm off the original Hyundai frame and slide the old  rubber out then fit the new rubber into the Hyundai frame and pop the swinging arm back into the main part.
Apologies as I have posted another thread on this.  Can mods merge please?
Offline Eggman
      Weston super Mare
The link you have put up is a different wiper to what I have on my car, mine is a flat blade, which I can't seem to find anywhere.
I guess I'll have a go at taking it apart and replacing just the rubber.
  • i30 1.6 Crdi
Offline baroudeur
I realised you have a GD but was not sure if a different style rear wiper was used on it.  Nonetheless, the link is useful for others as the range available seems to cover many makes and models.
As you are seeking a less expensive solution than a new Hyundai blade, if the fitting is the same as FD, why not use an FD blade?
Offline Eggman
      Weston super Mare
Thanks but I wasn't seeking a less expensive solution, I just wasn't able to buy one anywhere. In the end I managed to take apart the wiper and replace the rubber as described above.
  • i30 1.6 Crdi
Offline tohis
      Liperi
Did you try s g petch as they seem to stock most stuff
If not they will petch it for you!
 :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
