Doesn't time fly by
eye30 · 7 · 1535
Car is 3 yo next month, 16 May, so now due 1st MOT.
As it can be done up to 30 days before 3rd anniversary I've booked in for later this afternoon.
Expecting no problems as checked the obvious items such as lights, wipers, screen wash, seat belts.
Don't overlook tread depth ;)
And if you could check your own emissions while you're at it ... :whistler:
Best of luck :D
Only done 10,800 miles so depth is
Front  - centre 5mm edge 4.75mm
Back - centre 7mm edge 6.99mm
Emmisions may be bad today as just had beans on toast for lunch
This site is of use to uk members but gives info to others as well
http://www.motester.co.uk/mot-forum
Passed
No problems and sailed through.
Online Surferdude
:link: MOT Testing Forum - MOT Testing Industry Portal....
:fum:
I read that as "molester"
Edit. The link shows differently in Reply #3 to when I quoted it.  :undecided:
Offline Johnno
      Bolton, Lancashire
Its more difficult to fail a vehicle nowadays compared to 30 years ago, in them days I could prod the chassis with a screwdriver or hammer checking for corrosion, now your not allowed  to do that but you have to use a corrosion assessment tool  and if you see a tester using a screwdriver or hammer you can report him to VOSA ,there was no such thing as a advisory , it ether failed or pasted and there was a lot less things to check compared to todays MOT
