Wet road skid + ABS
rowanc · 11 · 4701
Offline rowanc
Hi All,
Driving this morning, and someone pulls out of a side road right in front of me, giving me a serious wakeup, hit the brakes too hard for the wet road, and go into a slide for nearly a second before the ABS cuts in (long enough, that I'd also removed some pressure from the pedal to compensate). Luckily this was all enough this time.
I tested the brakes on a backroad just after, and it seems that the ABS cuts in after around a second of skidding, for about a second, but then lets go again for about a second. It's like the pulse rate is 1/sec (from about 45km/hr). I would have assumed that the rate should be much quicker than this, as I had long enough to remove pressure from the brakes myself before the ABS cut in.
Is it normal to be able to skid for that long before the ABS cuts in properly?
Any thoughts folks?
Doesn't seem right to me, but can't recall ever having to brake hard enough in any of our 3  x i30's to test it..  :undecided:
Offline constipated
Agree, seems too slow.
Shouldn't skid at all.....There should be a thudding through the brake pad, and perhaps the slightest of chirps where the sensors compensate the pressure to ensure that you do not skid. You should not skid then recover.
you must go VERY VERY slow Dazz
Sit on the speed limits (usually as per the GPS), but read the traffic flow very carefully, mainly for economy reasons.  :cool:
I've only ever activated the ABS once and it was due to a moment's distraction (mine). However, once the pedal started thumping I eased back on the pedal pressure and was able to brake normally.
Certainly didn't skid first.
Offline elantraelite
      Melbourne, Victoria
Thats an interesting point you brought up. My 09 FD felt like it skidded before the ABS kicked in.
My 05 XD Elantra had a quick ABS system and it was only 3 channels! (2 to the front, one to the rear)
The whole point of ABS is to even things out.
As an example on a driving course we ABS braked on a road that was half wet and half dry. If the car had skidded for a second in this circumstance it would have caused the vehicle to become almost uncontrollable, as the tyres on the dry bit while the tyres on the wet  skidded...
Offline FatBoy
      Cygnet, Tasmania
I have used my ABS on my old FD.  It definitely didn't skid before it started working.  Unfortunately it didn't stop me hitting the wallaby.  The front number plate catches fur very well.  The rear right wheel has a lot of travel.  I wasn't speeding.
