How off centre is it and in which direction
had it with both my I30's,every time you have a wheel alignment done they have to reset the self centering control,my steering wheels never went that far off centre,but it was annoying seeing the wheel a but of centre,not sure how they reset it but once done hasn't happened again
I was just checking it wasn't just road camber, however as has been stated, it should be reset by your tyre specialists.
To check camber not the issue you need a road which will allow you to drive on the wrong side so you can compare a drive on the correct side and see the angle of the steering wheel then do the same length on the wrong side and see what happens.
Quote from: eye30 on May 06, 2015, 17:00:11To check camber not the issue you need a road which will allow you to drive on the wrong side so you can compare a drive on the correct side and see the angle of the steering wheel then do the same length on the wrong side and see what happens.Camber has been adjusted and is well within spec. Also, I did try what you have mentioned, and all though not as apparent, the issue is still there.
I don't know if this will work, but you could try: 1. Disconnecting +ve terminal from battery 2. Reconnect after a minute 3. start car. 4. EPS light will be on. Steer full left then full right. 5. turn off 6. start car again and test. EPS light will be offI know it recalibrates the angle sensor, but if it will fix an off-centre wheel, don't know, but might be worth a try.
I have that too! I don't know if I've always had it but when I changed my tyres I think I only noticed it then, so I went and had a wheel alignment thinking it was that and I mentioned this to the tyre place. After the alignment, it was still the same and the guy said that this was normal due to road camber, but we have 2 other cars in the family and they're not like this. I ignored the issue as the tyre place didn't see this as a problem as there was no tyre wear issue involved that needed to be addressed.I'm a bit p---d off now seeing that they need to electronically self- centre the wheel as part of this procedure.
If your handy with spanners loosen off the bottom knuckle on the steering column that goes into the bullk head gently slide it up and off the spline and turn the steering wheel anti clockwise one tooth and slide it back on and tighten and see how that goes
Quote from: Lorian on May 06, 2015, 17:37:01I don't know if this will work, but you could try: 1. Disconnecting +ve terminal from battery 2. Reconnect after a minute 3. start car. 4. EPS light will be on. Steer full left then full right. 5. turn off 6. start car again and test. EPS light will be offI know it recalibrates the angle sensor, but if it will fix an off-centre wheel, don't know, but might be worth a try.I wonder if this is the same as "reset the self centering control" .. if it is, it just might work. Thanks for the explanation on how to do it!
Quote from: Johnno on May 07, 2015, 01:58:30If your handy with spanners loosen off the bottom knuckle on the steering column that goes into the bullk head gently slide it up and off the spline and turn the steering wheel anti clockwise one tooth and slide it back on and tighten and see how that goesThe steering wheels on these cars are keyed, they cannot be manually adjusted by removal and replacement unfortunately. Not like the good ol days anymore.
Quote from: frankenzstein on May 06, 2015, 17:48:27Quote from: Lorian on May 06, 2015, 17:37:01I don't know if this will work, but you could try: 1. Disconnecting +ve terminal from battery 2. Reconnect after a minute 3. start car. 4. EPS light will be on. Steer full left then full right. 5. turn off 6. start car again and test. EPS light will be offI know it recalibrates the angle sensor, but if it will fix an off-centre wheel, don't know, but might be worth a try.I wonder if this is the same as "reset the self centering control" .. if it is, it just might work. Thanks for the explanation on how to do it!The "Steering angle sensor" is the term I know it by, too. I'm guessing the "self centering control" is just someone else's terminology for it.I did it slightly differently on the one occasion I had the issue earlier in the life of my car.Didn't disconnect battery. Found a flat (truly flat) section of road - drove forward about 20m with the wheel in the position it wants to take in the straight ahead - stopped - turn wheel fully left then fully right then to centre with spokes aligned horizontally. Fixed it. Think I found this solution on a BMW site.Along with several explanations of how it "couldn't work". It did.Maybe cruiserfied can offer something here. I seem to remember there's a tool Hyundai uses to reset the steering angle sensor and it's not available to everyone so unless the latest updates to wheel alignment machines have something added, I doubt non-dealer options exist.However, my information is about 3 years out of date.
Quote from: frankenzstein on May 07, 2015, 02:37:12Quote from: Johnno on May 07, 2015, 01:58:30If your handy with spanners loosen off the bottom knuckle on the steering column that goes into the bullk head gently slide it up and off the spline and turn the steering wheel anti clockwise one tooth and slide it back on and tighten and see how that goesThe steering wheels on these cars are keyed, they cannot be manually adjusted by removal and replacement unfortunately. Not like the good ol days anymore.I think Johnno is referring to further down the steering column. Not up where you would normally remove a steering wheel.
Quote from: Phil №❶ on May 06, 2015, 14:13:42How off centre is it and in which direction It is very slightly off to the right. If you center the wheel while driving, the car will veer to the left. More noticeable on the hwy at higher speeds... but it always does it.
Hope it works for you pidim.BTW, it seems Hunter is onto this issue. I've always found their wheel alignment equipment the most efficient so if anyone is getting an alignment done, look for someone with a Hunter. Then ask if they have this tool. Some interesting information here, too. CodeLink®, Steering Angle Sensor Reset Tool, Wheel Alignment Reset Tool | Hunter Engineering Company
Quote from: frankenzstein on May 06, 2015, 14:23:29Quote from: Phil №❶ on May 06, 2015, 14:13:42How off centre is it and in which direction It is very slightly off to the right. If you center the wheel while driving, the car will veer to the left. More noticeable on the hwy at higher speeds... but it always does it.What happens if your driving along in a straight line and you let go of the steering wheel do's it pull to the left or keeps going straight?
