Undercover boss Uk
Johnno · 23 · 5593
Offline Johnno
      Bolton, Lancashire
its on now Channel 4 Hyundai  bit late its already started
Its on again on C4+1 at 10.25 channel 143 on virgin
You'll have to give us a review
Offline Johnno
      Bolton, Lancashire
OK, they said techie's have it to easy and over paid and they're gonna cut the jobs time down by 50% :crazy1:  :blubber:
Assuming it is about Hyundai UK? Could be a repeat as we covered that one on here a year or so ago.
:link: HYUNDAI UNDERCOVER BOSS 18 11 13 1 - YouTube
Offline Johnno
      Bolton, Lancashire
Yep thats the one :whistler:
The workshop's looks old and dated compared to the showrooms. Don't know if all workshop's are built to the same spec across all locations, looked small and cramped.
Question for Tim, how are the job times [ do you have them] can they be easily completed in time.
« Last Edit: May 15, 2015, 11:39:02 by Johnno »
It's worth watching.. Nothing much seems to have changed since they did this exercise though. Still fairly crap service offered in UK by most accounts!
Offline Johnno
      Bolton, Lancashire
Can't comment on service not had one done since ownership. But when I first got my used car they said it had a full 20000 mile service, I don't know if they're suppose to remove the wheels or not but when I was fitting the mud flaps I had to use a rubber mallet to get all 4 wheels off? clearly not been removed since new.
Just the general feedback on here from UK owners with warranty claims and parts orders etc.. hasn't been "glowing".
Aussie feedback has been slightly better but still not stellar in most instances.
Offline Johnno
      Bolton, Lancashire
I think you'll find that with other manufactures not only Hyundai, different dealership's may have better customer service's and more knowledgeable technicians. I don't know how it works nowadays but in my day the workshop manager would get a memo saying that there was places available for a mechanic to go down to the training centre usually where the plant was on a weeks coarse, be it engine / gearbox or autobox and he would send someone who's not done one of them courses usually a new mechanic thats started. Apprentices normally went  on their final year as they where normally under our supervision  and you teach them what you learnt, you might go on one maybe once or twice a year and certainly when a new model came out.
I'm using my tablet now but someone might be able to give you a link to the previous thread to give you a better idea of the problems I was alluding to...
The original was in 2013 and the program no longer plays.  :'(
Offline Johnno
      Bolton, Lancashire
The one that Daz as put up works
Repeat..
Just watched it again. Still find the ending quite moving, rewarding those staff that helped his investigation.
I find that the best bit of all those under cover shows!  :goodjob2: :goodjob:
Cialis?   :undecided:
Hope you got a good result!   :D
 :crazy1:
The standard service times are achievable if nothing goes wrong.
Warranty times.......forget about it.
Offline Johnno
      Bolton, Lancashire
Nothing's changed with warranty times, Rover SDI V8 remove one bank and fit new head gasket = 40 minutes. We use to hate being allocated warranty jobs because you could loose most of your bonus if not all for the week if you got a few warranty jobs
Bonus is that thing that less skilled workers get for doing the easy jobs. I've not received monthly bonus yet. It's a sore spot to me and a couple of others.
Don't know how warranty costings work or bonuses, not in that industry, But I don't like the ideal of a technician being preoccupied about his bonus. :'(
Offline wbm00
      West Midlands, UK
A bonus gives them an incentive to skip tasks on a job and introduces the problems of gaming, solely to achieve targets. This is where problems occur. The problem is that an honestly run workshop will be at a competitive disadvantage to one that skips tasks on jobs to get through more jobs in a day...
Offline Johnno
      Bolton, Lancashire
It also has advantages for the customer regarding costs. Each job as a given time to complete the task.
One example. To replace a Jag XJ6 engine, the book time is 8.9 hours the .9 equates to 56 minutes, and that what's the customer gets charged. Another example where a job doesn't go to plan.
Did a insurance job on a Land Rover where there was a small fire under the bonnet, I had to carry out a inspection and see what parts needed to be replaced, I give the list to the receptionist who then cost's the parts and labour time, I get the go ahead to do the job but I come across a problem on one of the parts I fitted which was a flexi brake pipe, when I came to bleed the brakes I could not get a good brake pedal. tried different ways of bleeding it but still a crap pedal, in the end I stripped down the master cylinder and found the first circuit main piston seal had deformed possibly to the heat, took a total of about 3 hrs to rectify but the extra cost was a master cyl and labour charge to replace cylinder not the full 3 hrs.
So it does have it's advantages to the customer and not always for the mechanic
