The turn signal doesn't work periodically and when not working the hazard doesn't work either. Hence my conclusion is that the turn signal relay must be the faulty part, but where is that relay located..???
I've looked in the fuse/relay box in the engine room, not there, only the fuse for hazard lights. The sound when turning signal is on, comes from the fuse box located on the left side/end of the dashboard (don't know if they will be located in the RHS on a RHS car). Does anyone know the location of the relay or have a wiring diagram for this..?
I hope not the relay is a build-in part of the fuse box...
