Hyundai i30 rpm problem
vuleta · 8 · 5192
Offline vuleta
    • hr Croatia
      Zagreb
Hi to all,
I tried to find same problem on forum but didn't found it.
I have Hyundai i30 1.4, 2013y petrol engine.
It happens sometimes that when i change gear and want to accelerate rpm goes up fast my my car is at same speed.
I don't feel acceleration, no additional power, also for example I'm in 4th gear and he give proposal that I should switch to higher gear to 4th and rpm goes wild up.
youtube link from video what I recorded in my car.
:link: Hyundai i30 rpm problem - YouTube
I was on service and they didn't found nothing.
Did anyone had same problem?
Thanks.
  • i30
Offline omegaspeedy
    • nz New Zealand
      Pukekohe
Looks like your clutch is slipping. Can you smell burning when the RPM increases and no acceleration?
  • 2016 i30 Elite Limited 2.0L Auto Phantom Black Pearl
Offline vuleta
    • hr Croatia
      Zagreb
Yes I felt some smell when RPM went high, also told them on service but it seems to me that they don't know what are they doing.
  • i30
Definitely a clutch problem of some sort. How many KM's has the car traveled :question:
Offline vuleta
    • hr Croatia
      Zagreb
Yes I also think, I google litle bit and it's for sure.
I have only 75.000km
  • i30
Offline omegaspeedy
    • nz New Zealand
      Pukekohe
It wouldn't be uncommon to need a new clutch after 75000K if its been driven hard or if the clutch has been ridden too much, i.e. holding the car stationary on a hill using clutch and not the hand brake. Even hill starts using poor technique could accelerate wear (not suggesting you've done this, maybe a previous owner? :) ). Go and get some quotes from a brake and clutch specialist and get prepared to have a new clutch installed. I doubt there will be any form of adjustment available to get a few more kms out of your current setup. Really its no big deal getting a new clutch and it shouldn't cost the earth.
Offline vuleta
    • hr Croatia
      Zagreb
They changed my clutch under warranty after two visits and discussion with them.
But only after I saw that oil is leaking from clutch. (semering).
They also saw it but didn't want to admit until I didn't saw oil than they didn't make problem and changed without any more discussion.
I don't know is that quality problem with i30 or only happened to me.
  • i30
Not a quality problem with i30 quality (usually) Hyundai use quality mechanical parts like Bosch, Garrett etc...
Not a lot of premature clutch failures reported on here.  :cool:
