Not sure what the life of Diesel is, but I'd actually have a full tank of it, as it should provide protection to the inner surface of the tank, relating to rust issues. Any air in the tank will contain some moisture and an empty tank will expose a lot of steel. Can't say whether the tank of juice will be any good after 14 months though. I would do likewise with oils and coolant. Put the vehicle on stands, electronics into storage mode and battery on automatic charge to maintain a preset voltage.
One thing i remember from storing bikes is to fill (and i mean FILL) the engine with a special conservation oil, or top what's already in there with diesel, to stop corossion.That won't stop all the creepy-crawlys getting into the car, but it conserves the engine block.
Wow, really? Diesel in the engine all the way to the top? I'll have a couple of weeks to sort that out.
Quote from: The Gonz on September 26, 2015, 11:24:24Wow, really? Diesel in the engine all the way to the top? I'll have a couple of weeks to sort that out. I should clarify.I have heard to completely fill with oil.
Rent it out
Thanks, ibi. It's bound to be an original without code then.
