Removing rear fog lights from i30
Raid · 16 · 9114
Offline Raid
      London
  • Nobody is perfect.
Hello guys any chance someone can help me by explaining to me how can I remove the rear fog lights plz thanks.
  • I30 active 1.4 petrol 2013
Once you remove the rear inspection cover which connects to the bumper base then you'll have access to the rear fog lights, that's how it is with mine but the 3 doors have different fog light shape and placement compared to the 5 doors.
Are you wishing to replace or some other reason to remove?
Offline Raid
      London
Thanks guys but the reason why I would like to get access to that fog light is because someone hit my rear bumper and the parts that's holding the fog light inside broke so would like to fix that bit then take the car for repair. Will upload pic in a bit
Offline Raid
      London
I can push the fog light because the plastic part is broken inside
Offline Raid
      London
So will see if I can remove the inspection cover underneath the car and try to fix that part
Offline ibrokeit
  • Author of War & Peace
Well that sucks!
I think someone did previously post about removing the bumper - or a diagram of how it attached from service docs... but I not sure anyone has posted about the light in the rear bumper of the GD.
I suspect what you suggest will be the way to access it, and probably the way it is done for service... otherwise it implies having to remove the entire bumper to change a bulb (assuming rear twist in holder)... and I would assume, for the same reason, the mounts/clips for the light won't be hidden/blocked by bumper mounting.
Offline Raid
      London
Yep I think what craigB said o need to remove the inspection cover then will be able to get the the fog light and yep that sucks and been quoted £140 to get the bumper fix
Offline ibrokeit
 :oops: missed that it was (member 5716 not found) suggestion, and that he had done it.    :sorry1:  (member 5716 not found)
Offline Raid
      London
It's ok thanks mate maybe tomorrow or sometime will have to find a way to get to that part so that I can't fix it then get the bumper done
« Last Edit: September 13, 2015, 13:54:28 by Raid »
I take it you did not get the other drivers details for insurance claim as done when you were not with the car
Offline Raid
      London
That's right mate I parked it somewhere safe and they still managed to do that oh well
Offline wbm00
      West Midlands, UK
Hate it when that happens... have you spoken to the landowner to see if they have any info (e.g. cameras you aren't aware of) that could help? It'd be interesting to know the cost when it's been sorted.
Offline Raid
      London
I was very angry when I saw it but nothing much I can do as its on the street and i have been checking at some other cars of they have any scratches on theirs but no luck and I have been quoted £140 to paint the bumper and I will have to sort out the rear fog by myself.
