The first thing to check is if the connecting pins are available and if so do they have wires attached.
A little history, I have just installed cruse and radio controls to the steering wheel of the wife's 2011 1600 Diesel SX I30 poverty model (I know, different vehicle to you) but this is what I discovered.
There is only one row of pins in the clock spring, not a problem, I went to a wrecker and for AU$125.00 got a leather covered steering wheel with the cruse switches installed, oh, and the clock spring underneath as well, it has pins 1 (horn), 2 (CC ground), 3 (CC signal), 4 (CC power), 5 & 6 N/C, 7 & 8 (radio), 9 & 10 back lights, 11 & 12 N/C.
The dealers wanted too much for the Y wiring harness and I had half of it in the new steering wheel so I got a 56192 2K200 that had the right plugs (wrong wireing, excess stock I think) and the radio switches for the LH side. That left a strip and re-wire job that left me with three sockets for the plug on the other side of the clock spring to continue the re-wireing to the ECU.
The Y harness and ECU connections are as follows:-
Clock Spring. Cruse. Radio. ECU.
1 horn
2............................6.................................89
3.............................7.................................9
4.............................8..................................50
5 N/C
6 N/C
7.............................................6
8..............................................7
9.............................2................2
10............................1................1
11 N/C
12 N/C
Unfortunately that was as far as my checking for available blank connections went, ECU pins 51 (CC set) was unused BUT I then discovered pin 44 (engage) was already occupied with a green wire
After hitting that brick wall I muttered a few four letter words and decided to give it a test run anyway, the radio control worked, no surprise as the wiring from the clock spring forward was already existing
the cruse engaged over 40 km/hr and disengaged with the brake (it's an auto) or the steering wheel control, happy life (actually, happy wife), no need for plan B, a (expensive) after market cruse control kit.
I would be very surprised if your ECU did not have the CC software already installed, there is a lot of information and links on this site, sift through it and then have a close look at your plugs to see if anything fits, don't forget plan B
50.....................
