0 Members and 15 Guests are viewing this topic.
Tested :- no fault found.....
There was a TSB for a knuckle in the steering which used to wear prematurely. Hopefully it is just that, because if so it would be cheapish...
http://club.hyundai-i30.ru/download.php?id=2907 (pdf, 1mb)
It's not what you know, it's who you know..
Have the same knocking sound in mine when driving on uneven surfaces. Have replaced both drop links and both steering rod ends but can still hear the noise and feel a little slack in the steering. This TSB would likely be the culprit in my case as well.
... But first, read my description above in the first post. If that fits your problem then it's not really a big deal.
Quote from: Surferdude on June 16, 2016, 10:11:47... But first, read my description above in the first post. If that fits your problem then it's not really a big deal.Hey surfer dude did you experience it when driving? My wife normally drives the car and after reading thinks it's worse case than yours. I myself have been driving and felt the clunking in the steering wheel and when turning feel it clunk/click. It's both at low and higher speeds (roundabouts, corners etc.). I'm looking into a power steering specialist in Sydney now.
