Engine shutdown at low speeds and stops
ng · 6 · 4330
Offline ng
Hi All, my 2009 i30 petrol automatic gear has an intermittent problem: from time to time my engine shutsdown while waiting at traffic lights and recently happened driving in low speed as well.
Other signatures happen the same time:
1. ESP OFF yellow light turn on
2. When trying to re-ignite there are few options that happen:
    a. in most cases - can not ignite on first try, car is shaking, eventually it ignites when i hit the gas but ESP OFF light still on   and car is faltering while driving. I must stop and re ignite
    b. Some time can re-ignite immediately and normally.
 and sometimes the RPM stays on 0 and I hear a clicking noise and i feel that the gas peddle doesn't react normally until I stop, shut off and re ignite.
I connected to the computer and only got an ESP error. I cleaned the throttle as well and it helped for a week.
Do you have an experience with such problem, what was the diagnostic and the fix?
Noah
  • hyundai i30
Offline CraigB
      Perth, WA
At first thought I was thinking maybe fuel filter or dodgy injector but if your getting a fault light up then maybe that could be the cause :undecided: looks like a trip to Hyundai might be required for further investigation.
Offline ng
Im getting my "rpm sensor" reaplaced.
They say thats the problems.
Ill let you know.
  • hyundai i30
Ill let you know.
Wow! That was quick!  :eek:
 :welcum: to the club!
Offline ng
Almost a week without any problems.
I think they fixed it.
Solution: replaced the "RPM sensor".
Thanks for the help.
  • hyundai i30
