Change the H7 light bulb help ?
niklas · 7 · 3496
Offline niklas
Good evening, everybody, I have just changed my light bulb in the lenses, but now I se a lower H7 bulb, is that the high beme? I know the one next to the lenses are static turn light. But now i only have the new bulb in low beme right? So I need a total of 6 H7 ?
I'm not sure what bulb the static turn takes as I don't have that one on mine, but the H7 Low beam is behind the projector lense ( the large arrow pictured )
The H7 high beam is the lower picture which sits directly beside the T10 park lights.
Probably no point checking my UK static bending light for you as my high beam is H1 not H7, so there's a difference already.
That's interesting, I thought the GD used H7's for both...  :undecided:
Offline AleM
    • es Spain
      Malaga
Static turn and low light uses H7, high beam I think is H7 too,at least in Europe.
In i30 GD
  • 2013 GD 5 Door Hatch, Diesel 1.6lt (110CV/81KW), Manual, Steel gray
Offline niklas
As i can see High/low & static is a H7 on the euro model. So i need 4 bulb more  :faint:
Quite correct - I was thinking my GD was the same as my FD.
Just checked the book -
  Low beam: H7S or D1S
  High beam: H7L
  SB light: H7L
