This is a new noise is it normal
bensintic · 46 · 12917
Offline bensintic
That clunk when accelerating you can hear it when I'm driving as well????
  • i30 gd2 petrol
Sounds a bit odd!
@cruiserfied
Bit odd. Sounds like your "snapping" the throttle and its knocking before it gets a chance to rev up.
How many km's and whats the service history? What fuel do you use?
Offline bensintic
Serving is good 42k it's been like this from 7k can you plz help me so I can tell the dumb Hyundai they say it's normal no it's not
  • i30 gd2 petrol
Offline bensintic
Normal 91
My rpm is slow and dips and so sluggish
  • i30 gd2 petrol
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
That is strange, Sounds like a solenoid to me. :undecided:
  • Toyota Kluger KXR AWD
Offline bensintic
His when I 1st start it
  • i30 gd2 petrol
Sounds like a diesel to me, what's it behave like when you rev it normally "without stabbing the accelerator"
Offline FatBoy
      Cygnet, Tasmania
A couple of them sounded like the engine "bogging down" when you first put your foot on the accelerator.  It sounds like the mixture is wrong, either too lean or too rich (probably the latter).  Have you tried running a premium fuel in it to see if it is still there?
With the clatter & choofing coming out of that you'd swear it had quite a few hundred thousand k's on the clock...  :eek:
Offline bensintic
Slow when I rev the rpm slowly comes down  it use to be fast
  • i30 gd2 petrol
Offline bensintic
42k on it
  • i30 gd2 petrol
Offline bensintic
I tried 98 still the same its bit better on 91  it Boggs down around 1500RPM
  • i30 gd2 petrol
Offline bensintic
I have to repress the gas for it to do
  • i30 gd2 petrol
Offline bensintic
Sounds a bit odd!
@cruiserfied
What would you think it is
  • i30 gd2 petrol
Offline bensintic
What kind os solenoid
  • i30 gd2 petrol
Might be my ears, but to me it sounds like the AC compressor bolts are loose.
Offline bensintic
You think so what bolt
  • i30 gd2 petrol
The bolts that secure the compressor in the serpentine belt loop. As you blip the throttle I can hear something moving under the increased tension.
As I said, might just be my ears.
Offline bensintic
Dose yours do that
  • i30 gd2 petrol
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
Yes that sounds feasible, in fact you saying the AC has triggered what I was trying to think of when I mentioned  a solenoid and that is the clutch pulling in on the AC compressor, that makes a fair old clunk.
Phone recordings tend to increase the sounds of engine noise as that is what they are designed to do to normal voices.
 I wouldn't take too much notice of the sound levels. Investigate the AC pulley clicking on or off. For a test like that, the AC should be off.
Offline bensintic
I shot that in 4K video
  • i30 gd2 petrol
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
Did you try what Phil suggested with the air conditioner turned off ?
Offline bensintic
The aircon was not on
  • i30 gd2 petrol
Offline bensintic
I've got my computer at full volume and I can barely hear that, I honestly think you'd be better off taking your car into Hyundai and explaining your issues to them with your videos.
People can only speculate what these noises are but unless you take the car to Hyundai to show them then it's only ever going to be speculation.
Offline bensintic
It's not noise the lights dim
  • i30 gd2 petrol
As the title of the topic states "This is a new noise is it normal" so I assumed you were trying to further discuss the noise that you've already queried, that'll teach me to assume :confused:
Anyhow it would still be the same answer that you need to bring up your queries with Hyundai, imo the lights shouldn't dim like that but I've no idea why it's happening  :undecided:
Lights dimming is perfectly normal.
It can be a result of any of the following conditions
  • RPM of alternator
  • Electrical load
  • Voltage regulator cut in / cut out
  • Batteries ability to accept charge
  • All Eathing pionts and + contact points
All perfectly normal to me.
