Parking lights stopped working
Offline ThunderStruck
Hello everybody,
Last night I saw that the left low beam doesn't work anymore. After a quick check I decided to buy Osram Night Breaker Unlimited H7. Then I watched a few videos on how to replace it and did it myself. It wasn't so hard nor so easy but it is kinda fine now... until I saw that now the parking light on the same side stopped working  :crazy1:. And I am quite sure that it was working last night when I found out about the low beam.
However, my questions are, is it possible that I have done something while replacing the low beam, which I kinda doubt, as I haven't touched anything near it? Have any of you encountered the same problem? :)
So far, I tried to move the small bulb around just in case it was misplaced or something but it didn't help.
P.S. The model is i30 2011 1.6CRDi.
  • Hyundai i30 1.6CRDI, ISG
If the left taillight is still working, then it's not the fuse.
Most likely the fiddling around have caused the bulb not working anymore. I'm sure a new bulb will solve the problem.
