Can i put oem camera on hyundai i30 -2013??
Ipgoogle · 20 · 14062
Offline Ipgoogle
    • ps Palestinian Territory, Occupied
      Ramallah
Hello every body ,
I just buy anew car its hyundai i30 - 2013 - GDI - 1.6 - petrol.
The car have all acsseroies i need but dont have dvd ( touch screen ) and oem camera that come under the hyundai logo in the back of the car.
I see another cars have this camera that when u put R in gear the camera come up from the logo and when u drive on  D  , the hyundai logo come back normal.
So i want to buy this camera and dvd BUT the car have all wireing and just need to connect the camera and replace logo ? Or i need anew wiring to be coneect in the car ?
This is the camera
:link: Genuine OEM Rear View Trunk Camera 1p For 2012-2015 Hyundai Elantra GT : New i30
  • hyundai i30 vvt 1.6 2008
Wow! not cheap!
I would inspect your tailgate to see if there is the necessary cutout under the logo. I would not be surprised if the models with this feature have a different boot skin. Only guessing though.
While the genuine article is a neat option there are lots of much cheaper options...
:link: reversing camera | eBay
Offline chris_i30gd
    • gr Greece
      Greece
I have installed :link: Auto.Vox IP68 170° 6LEDs Night Vision HD Car Parking Rear view Reverse Camera | eBay  this cam and it's awesome.
I have an aftermarket android 5.1 navi dvd also.
It's really great and much cheaper than oem
  • hyundai i30 1.4 crdi 2013
guest9517
Just bought such a camera from an 2016 for 100£, will inform how to install (or burn  :evil: ) once if received it in a couple of weeks  :)
I installed this and I am very impressed with it. :goodjob2: :goodjob:
NanoCam Plus
guest9517
NanoCam Plus
Which is fine, but i already have a front recording camera with input to my 7" 1200*600 android unit, so would be a bit "cheap" to put an extra mirror on top of the original.
...I already have a front recording camera with input to my 7" 1200*600 android unit, so would be a bit "cheap" to put an extra mirror on top of the original...
I fully agree. If I had an Android unit already, I'd be feeding the video into it, in which case, buying a simple aftermarket add-on camera should work well, on or off the swivelling logo.
guest9517
I now have the connections for control of the open/close sequence:
Red wire: Battery (+)
Blue wire: Ignition (+)
Green wire: Reverse lights (+)
Black wire: Ground (-)
Yellow wire, not needed, unknown func. Probably some kind of feedback as voltage is approx 10,6V in closed position & 10,4V in open.
Above is only for cable that goes to the movement-part, camera will be tested tomorrow but quite sure its:
Red for Reverse lights + (to only have camera powered when needed)
Yellow OR white: Video, other color is probably video ground.
I am unfortunately not allowed to bring any camera to where i do the testing, but i did take the movement-enclosure apart to measure diodes on PCB to be sure not to kill this part when testing which pins is for what. But it actually seems like they have been careful to put diodes on all +/- inputs.
The camera i have is for the European market, there might be differences on Korean models. (The one i got has Part No: 95760-a6330 )
guest9517
Camera tested & above connections is correct. Due to i used a 10 year old headunit, i had some issues around getting sync on video-signal, but all solved in the end. Unfortunately due to swapping around, in dont remember what was Video & what was ground of the white/yellow wire...But nice good picture from cam, so next step will be to get it installed before winter arrives :-)
You should be able to determine which is ground by no or low resistance to chassis earth. The other will be the signal line.
guest9517
Yes, but when i realized i forgot how the videooutput from the cam was connected, the test-setup was put away & cam already put back in its packing. Theres no possible damage at all if video & ground should be mixed up, so reason i put it that way here :-) But good point if anyone should follow in my footsteps :goodjob:
Nice job. I like that hidden camera concept. Pity they didn't keep that up on the PD model. The exposed cameras (on most brands of car) are pretty useless if the get dirt or water on the lens (which they do)  :cool:
Offline aanastasiou4
    • cy Cyprus
Can you explain us the process? Was the wiring already placed in the tailgate?
Sent from my iPhone using Tapatalk
  • Hyundai i30 2012
guest9517
I found out the ignition-signal from my stereo wasnt delivering enough to get the camerasled out all the time, so put a relay on ignition-supply to the headunit (Which as far as i remember only is 3 volts).
You need a dremel or so to grind away metal behind the logo to get space for the camera.
Theres an old link here, with a russian guy (i believe he is), that eventually gave up, but with quite good description of the process. i have used google translate on the page :-)
:link: Google Oversæt
Offline i302013vn
    • vn Viet Nam
      Hanoi
Hello every body ,
This is the camera
Thanks for your information.
My car is also i30 2013, but  it's same to your car before, no OEM camera under Hyundai logo and DVD. Last year, I tried to order an OEM camera from Korea and a DVD in Vietnam. After installing, the camera and dvd worked well except the Hyundai logo didn't turn to present the camera. I though that the camera's hinge didn't receive control signal to turn or something else that I didn't know. The camera I bought is in attachment. The DVD was kept for entertainment, and the camera was removed.
Would you mind sharing me where did you buy the camera, its model/serial number. And how to install it?
Thank you in advance
  • i30 2013
guest9517
I dont believe that my cars wiringharness is the same as yours, as mine is made in Europe & after buying several components to it directly from Korea, (cruise control & auto-light), where only auto-light fitted & i had to redo almost all wires to get the cruise-control to work.
You could try to add:
To the cables that goes into the upper box (not the camerapart), if you add +12V to the red, blue & green wire at the same time, while having ground on the black wire, the camera should come out nicely on its sled. If not, its probably faulty and if it does, you need someone to measure the connector on the car to see what is missing there :-)
It´s -3C here, and only place i got any numbers is on the camera, so unfortunately i´m not going to check the numbers for you, sorry ;-) But i bought it on Ebay from somewhere in europe, simply dont remember where, but think that doesnt matter as long as you try what i described with the 12V :-) Good luck  :goodjob: & feel free to ask again if you believe i can help you any further :-)
Hello every body ,
This is the camera
Offline i302013vn
    • vn Viet Nam
      Hanoi
Thanks for your feedback. I will give this to my local garage, hope they help me to upgrade. Maybe still need you support on technical :)
Hello every body ,
This is the camera
  • i30 2013
    • cy Cyprus
So, what is the result? Have you installed the camera yet?
  • Hyundai i30 2012
These pop out cameras are a great idea. My stepdaughter was lucky enough to get one in the 2016 SR Premium she recently bought. I wish my MY18 PD SR had it. Stops the camera getting dirty.  :goodjob:
