08 i30 diesel fault code C1611
chaddd · 2 · 3194
Offline chaddd
      South Australia
Hi Guys,
My car has been sitting at the mechanics for the last couple of days.(luckily I don't need it) anyway the problem it is having is ESP off light is coming on and I'm loosing power for a short amount of time and also it will occasionally rev higher then idle when it is meant to be idling.  This all happens randomly but seems to be getting worse. The mechanics scanned it and it brought up the fault code C1611  I've done a little bit of googling about the fault code but can't find much on it. The mechanics have replaced the abs control unit.. Not 100% sure that's what it is called anyway they replaced it and it didn't fix the problem.. Anyone got any idea's where to go from here? Has anyone has any experience with this fault code before?
Cheers,
Chad
  • I30 Diesel 1.6 08
Offline diesel1984
C1611 CAN time-out ECM
This can be triggered with low battery.
  • 1.6crdi
