0 Members and 17 Guests are viewing this topic.
Hi fabulatuaestWell, my GD has audio-visual front park assist alerts; the audio beeps with increasing regularity when something is within range while the dashboard shows which of the corners is causing it.Couldn't reall get much worse than that, could it?
Sorry mate. I was disappointed with the product. Over $600 wasted. Still trying to deal with the mob that supplied it.
I'm thinking I might be able to swap the value for a couple of services.
Thats funny, the beeper ones on the i40 work just fine, whats the difference?
Booked into Motor1 on Friday so will see what can be done to rectify this.
Factory. They arn't linked to a screen, but do they need to be. Long beep = you are getting close to hitting something.
Ok, went in to have the front sensors "fixed". They put a rear module in with the front sensors which is audio only. Turns out it was a waste of money in the end. They still go off for no reason and at speed. I can use them provided I remember to turn them on when parking. Meanwhile, they stay turned off.
Good thinking. Good luck with the trip.
Hi mate, glad you had a good time.Have had my front sensors replaced. Still no better. I asked if they could be hooked up to the door lock module so it would deactivate when the doors locked when driving. They said that they could not do that, meanwhile, I just do not use them.
Thanks, Dazzler, for the follow up. May be stuck with mine as they may not take them back now. I need to take my car back to them in a fortnight for some paint protection touch up. Will talk to them then.
