Anyone used this brand?
I ask because today i bought one and when i took it out of the box i find that on 2 opposite sides there are what appears to me 2 extended flaps.
On one is an arrowe showing direction of air flow.
The filter will not slot into the grove with the flaps up.
If i bend to lie against then they just spring back.
If i bend back and slot into grove the rear one just springs back and i can not replace the cover.
Now the options are
Cut off or bend back and stick with tape.
If i bend back this then shows the arrowe direction in the opposite direction.
Views re suggestions on correct fitting appreciated.
Sorry about pictures as they should be turned quarter. Steve how do i do it.
