I change the turn bulbs with led because low amp they start blinking fast
Offline NATHAN_P
    • il Israel
I change the turn  bulbs with led and because of the low amp they start blinking fast.
There are too options ,
1 install resistors betwen the pos and neg wires 50 W 6 ohm but i don't wont a barbecue inside the car.
2 change the turning relay with  an new electronic one Electronic LED Flasher Relay for Car Turn Signal Light Adjustable from 0.1 W to 150 W.
The second option is more friendly , but i don't know how many pins in the  relay , to order before i disconnect it   3, 5 ,8  and where is located.
Does any body  have any picture or there is a youtube or the model that will fit? :sweating:
  • 2013 5 Door Inspire, Petrol 1.6lt, Auto, Metallic Gray
If it has a relay ( the GD model doesn't) it'll be in the fuse box inside the engine bay I think :undecided: there will be a placard stickered inside the cover that will show which is the relay...if not there it'll be in fuse compartment under the dash.
I'd be leaning towards inside the car, that's why you can hear it click.
Offline NATHAN_P
    • il Israel
Thanks any way but i think it is inside the car, that's why you can hear it click. :neutral:
