Handbrake loose
i30joe · 10 · 7280
Offline i30joe
      Jarrow
This morning as I disengaged the handbrake as usual. There seems to be a lot of play when the handbrake is fully down and it even lifts to a point where the warning light is lit on the dash.
I'm a wannabe amateur mechanic and I've never done anything with handbrakes.
Do any tips would be greatly appreciated.
Joe
Sent from my SM-G930F using Tapatalk
  • 2011 i30 crdi comfort
Joe
Parking brake lever stroke :
7 cliks (Pull the lever with 20kg)
There's 2 adjustments. One inside the rear disc assemblies and the cable adjustment inside the center console.
I don't fully understand what you're on about with the lamp but as soon as that lever is lifted the lamp should be on.
If the ahndbrake holds fine but the travel of the handle is a bit long then adjust the nut in the console to have it to spec
Joe
Taking a punt from miles away, it sounds like a cable  has come off or is broken. Check 'A' at the rear hubs.
Has play just happened?
Still under warranty?
If so get dealer to rectify
it's 2011 model and brake adjustment would be considered routine maintenance not wty
Offline i30joe
      Jarrow
Thanks for the replies followed the instructions from the video provided and is now as tight as a nuns chuff Dazz
:sweating: :faint: How would you know that specification? Good to hear you've got a grip on it
 :rofl:
Ooops ...Convent humour
Shambles will have us banished  :mrgreen:
I've made it more acceptable... but still accurate :whistler:
