Scuff Plates - better late than never
CraigB · 63 · 17950
Offline Jeff70
    • Launceston
There's also a very good reason I DIDN'T option the sun roof.
  • i30 SR 2017
That one is a LOT easier to justify...
$2000, risk of shattering, risk of leaking when gets older, ongoing cleaning of channels and possible maintenance issues.. Reduced headroom in some models, Possible extra weight (not sure if it's heavier than a steel panel though) :undecided:
Have you got another reason?
I can understand how a sunroof would add weight as you have the glass - framework and drainage system, though 0.6mm pressed stainless steel sheeting is no heavier than the plastic scuff guards that were removed.
The packaged weight including the tube the guards were posted inside of came to 600 grams, and I would think 400 of that was the cardboard tube :)
Offline Jeff70
    • Launceston
I've always been a "weight-weenie" though.
I'm the same with my road bike....super light (and expensive).
Yeah,the sun roof MUST add extra weight,right where you don't want it.
But don't worry..I'm not going to break out the drill and make everything look like swiss cheeze........yet :)
  • i30 SR 2017
Online The Gonz
That's it, I'm deciding to mount the LED bars on the underside of my nudge bar, to keep CoG as low as I can get it.  :lol:
And try and get some Aluminium or Titanium screws!!!!
Found a couple of different styles for you guys/gals with the PD models
:link: i30 PD : [DXSOAUTO] Hyundai i30 PD - AL Hairline Slim Fit Door Sill Scuff Plates Set
:link: i30 PD : [DXSOAUTO] Hyundai i30 PD? - The Standard AL Door Sill Scuff Plates Set
Thanks Craig.  Not sure I like either of those. Hopefully the earlier model ones I've ordered will fit.  :undecided:
Surely Gonz has got some contacts in his industry.
Online Pappy
      Australia, Sydney
Hi Dazz, just checking if you got your scuff plates and if they fitted OK?
I'm looking at getting some cheaper ones too.
  • MY18 PD SR Premium (Polar White)
My wife says a long parcel has arrived but I'm in Western Australia until Saturday. Won't actually get a chance to check them out until at least Monday when I collect my car from the body repairers.
Offline Purplehazeffc
      Australia, Perth, WA
I received mine last Thursday.  Due to work I hadn't had a chance to look at them till yesterday.
They do look OK, but don't fit perfectly.  The slight curve of the sill in the PD must be different.
So a little bit of bending & even supplying your own double sided tape will be required.
Did they eventually sit ok , or have you only done a trial fit?
I have only done a trial fit at this stage.   The plates have a turn down curve piece at the ends
That make them not fit flush with the sill.  They can be made to fit though.
but not a direct stick on
Thanks, I'll check them out when i get home. Could I grind a tiny bit off the ends?
Are those one's designed to replace the factory plastic scuff plates or mount directly over the top :undecided: I originally thought mine were to mount over top but realised later the plastic one's had to be removed...the plastic ones broke to pieces removing them so luckily I had no need to keep em.
They're very thin Dazz, if I were to trim them I'd probably use a pair of good quality tin snips, if you hit them with a grinder they'll discolour very easily.
Fairy nuff.. I'm fairly good at modifying stuff... :goodjob:
To me, they look like they are designed to go over the plastic.
But that can't happen with these as they are quite a bit narrower.
They don't look to bad. But one day I might end up buying ones that
are made for the PD.  If you look at Craig's 1st post. Those a wider.
« Last Edit: July 17, 2018, 18:40:21 by CraigB »
That brought back memories...last guy who said that to me spent the next 15 months with his hand in traction after borrowing my 9" grinder to cut a wall register, grinder torque kicked on him and went straight through his wrist :eek: I did warn him about the kick :disapp: the same guy now owns the company my brother contracts to and always reminds him of the day he borrowed my grinder after telling me he was experienced :rolleyes:
Yeah they're to long and narrow, pack em up and put them in the forums for sale section for a GD model, Dazz can at least put his one's on the wife's car :)
« Last Edit: July 17, 2018, 18:42:23 by CraigB »
I think they look ok. Trish said she doesn't want hers swapped.  :whistler:
Tried to swap mine today. They are different to the ones PurpleH got. Mone have a little black rubber or plastic seal around the edge which make bending them trickier. I aborted the swap but may try again sometime with a bead of silicon rather than tape.  :goodjob:
They're quite narrow aren't they, they would need to line up with the outer sill edge edge to provide adequate protection and then they might not cover the clip holes in the sill.
Dazz, I'd send em back for a refund myself, being that narrow they are not really fit for purpose imo :disapp:
Nope. That is exactly the ones that I have got as well.  They look to me to go over the plastic rather than just on the bare metal.
I used some pliers to bend the ends straight. Then bend by hand to suit the contour of the sill..
I used some strong 3M double sided tape that I replaced the stuff that is on there now..
But I will look into getting the proper fit ones that suit in the future though..   They don't look that bad,,
They will work if I am patient.  If not I'll find a Tassie FD owner to give them to. :victory:
Just saw your latest post PurpleH. Yeah yours look ok.  :goodjob:
Offline LemurMort
    • hr Croatia
While they do look nice, I have a different problem.
Seems to me the previous owner had a bad habit of rubbing feet on top of the side skirts when entering the car.
The result: bare black plastic surrounded by a beautiful red paint. What can you do...
  • 2010 FD 5 Door Hatch, Petrol 1.4 + LPG, Manual, Red
Side skirts you would need to paint them or see if there is a similar vinyl wrap colour to cover with :undecided: a picture might help to make sure we're talking about the same thing.
Offline LemurMort
    • hr Croatia
Sorry, I'm not able to put picture of my own car picture. Hopefully, this will do.
Marked red is a side skirt, marked green is where it is damaged.
Only, the damage is on the driver's side.
I'm afraid I'd have to live with this. If I take the skirt to repaint it, it'll cost a lot.
It's not really noticeable until you look at that part of the car but it still bugs me a bit.
What can you do...
You could get some paint made up/colour matched if you just want a quick fix to eliminate the black scrapes, that's about the cheapest option you'll find next to vinyl wrapping the top of the sills/scuff plates.
