DRL Help headlight or parking singnal
i30kk · 9 · 2523
Offline i30kk
      NT
Hi everyone, I just bought a pair of DRL FOG light  from korea and ready to install it. instead of join/tap the singal wire to the park light/headlight wire loom,
 is there any other way to give singal to the controller box to turn off the DRL? like a fuse tap? or?
lights that i brought :link: Fog Light LED DRL + Cover + Short wiring (Fit 2011+ HYUNDAI i30 Elantra Touring) | eBay
thanks
« Last Edit: September 02, 2018, 08:14:10 by i30kk »
  • i30 Active X
:welcum:
Post a link to the product and we'll see what we can do. :victory:
 :welcome:
So yours is a GD (series 2) hatch I assume? That is where photos would be handy.
Just click on the "add image to this post line" and follow the instructions.
Offline i30kk
      NT
thanks , thats correct. I want to know is there any fuse that gives power when headlight is turned on
  • i30 Active X
The DRL’s are designed to switch off when headlights are on, there should be a harness available.
Offline i30kk
      NT
yes, that's what I need to know instead of damage the headlight wire to give signal to turn off the DRL, what else  can also give singal to the harness to turn it off ?
  • i30 Active X
The harness should include something like red and black wires going to ACC and GND respectively, and a white wire that goes to your headlight feed. The DRL will then use the white wire's signal to turn off.
You can make up your own harness with a relay and some simple logic. :winker:
Offline tla
IIRC: For the FD model, there was a separate fuse for the headlamps from which you could tap a signal.
But with the GD, and maybe the PD models,  the headlamps and parking lamps are fed directly from a "smart junction box" which is collectively powered through a 60amp fuse.  So, AFAIK the only route is to get your signal straight from either the headlamp or parker wires, as you already noted.
There is a DRL fuse in the driver's fuse box but I haven't looked to see how that works yet.
