Quote from: Markyc95 on March 23, 2019, 14:51:05Hi I had the same problem for months. This was cause by a previous owner installing a 3rd party clutch. Swapping it for a genuine Hyundai clutch solved the problemWas anything else changed?, could you check or post itemised invoice if you still have it please.
Has anyone checked out the driveshafts on this in particular the inner joints. Most susceptible the longest shaft. There may be evidence of grease leaving the boot under the clamp.
Quote from: tw2005 on April 04, 2019, 21:21:41Has anyone checked out the driveshafts on this in particular the inner joints. Most susceptible the longest shaft. There may be evidence of grease leaving the boot under the clamp. Noooooo! It has to be the clutch.Its always the clutch. The Lord sayeth New thoughts are the Devil thinking.
ITS FIXED!!!!Another new clutch, and this time a new flywheel and the vibration is gone.
Quote from: hoolydooly on May 01, 2019, 06:04:23ITS FIXED!!!!Another new clutch, and this time a new flywheel and the vibration is gone. well I guess we can say Holy Dooly it's fixed, glad it is and `~I had my doubts on the clutch but t, there you go
Quote from: tw2005 on May 01, 2019, 08:13:43Quote from: hoolydooly on May 01, 2019, 06:04:23ITS FIXED!!!!Another new clutch, and this time a new flywheel and the vibration is gone. well I guess we can say Holy Dooly it's fixed, glad it is and `~I had my doubts on the clutch but t, there you go No oops mate. You are ignoring your research principle.Clutch and flywheel were changed. Which one was at fault?
in 5th gear at around 100km/h, the vibration started just below 2000rpm as normal, but I was watching the speedo and it was jumping up and down by 10-20km/h,....
I had this on my FD just before it's 5th birthday (5 years ago). 1800-2000rpm rattle/vibration only in 4th/5th/6th.IIRC they replaced the flywheel and the noise remained.They then replaced the clutch and all was good.I seem to recall they believed it was an issue with springs in the clutch.
I don't know about causing the vibration, but if you put clutch springs into our search engine there are lots of references about them failing or getting worn or loose...
It would seem, that after much discussion on noise/vibration re diesel engines, that maybe there is actually 2 or 3 different sounds/feels existing all being interpreted as "the same as mine".1- certain gear/ engine rev,2- clutch issues 3- exhaust harmonics.
