Top centre compartment Disassembling
kosmolino · 16 · 11484
Offline kosmolino
My top center compartment (at dashboard head) is fixed (no compartment).
I want to remove my radio - how do I open it?
Offline bfc_xxx
    • gr Greece
Newest i30 models are made in Czech republic. Those dont have a top compartment.
Also mine is the same and how to disassemple is a mystery also for me.
Hi guys.
Have you clocked this thread? Some ideas there might start you off...
Offline kosmolino
I got it !
It is so easy.
I just finished pulling the center compartment and installed the parrot headset.
there is no need to open the center compartment in order to reach the radio. You just need to pull out (towards you) the whole panel.
Start with the clips on the lower part (near the air condition switch) and then the upper part - just place the proper tool between the rubber part of the dash and the center compartment and pull it towards you
hear are some pics
Offline bfc_xxx
    • gr Greece
Good work Kosmo. What did you use as "the proper tool" ?
Offline kosmolino
The tool I'm using is a standard tool for dashboard removing but I believe you can use any sharp plastic which look the same
Thanks Kosmo. Looks like a standard crow bar would also do the trick :lol:
Offline Myowni30
  • Midlands, UK
Works with the doors as well  :lol: :lol: :lol:
Offline Hemmi
    • is Iceland
      Reykjavik, Iceland
I see it ...but I don't believe it.. :eek: :lol:
Looks like an expert :rolleyes:. Maybe he could do a video showing how to remove the top compartment :lol: :eek:
Offline teglasia
Hi!
This post sounds helpful regarding the removing process of dashboard in Czech manufactured i30. You attached some pics but I can't open and check them. Could you please send me those pictures to me (teglasia@freemail.hu)
thanks
A
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
Hi there and welcome
Unfortunately the pix on this thread have been corrupted when we moved host and unless the OP comes back and reposts them we have no way of rescuing them.  Sorry :'(
I guess there may be other old attachments that are corrupt too, all the more reason that people should take heed of the warning and host photos somewhere else, and not include them as attachements, as it can be a disappointment to go back to old articles and find no pics.
The really important thing to know about the missing pics is if you have a Czech built car with no top cubby hole/storage tray (production from around July 2009 onwards) DO NOT try to prise the top off, it won't come out, and you will damage the dashboard.
Offline teglasia
Thanks for the warning, helpful.
My i30 was manufactured after the mentioned time so it has an underneath fixed top. I've found some info about the removal of dashboard. From the bottom (AC switch) to the upper part of dashb with a plastic device in the gap between the hard and soft part of the dashboard the hard part can be removed.
