0 Members and 17 Guests are viewing this topic.
What !!,What happened to the Red Fake Brembo caliper covers ??
The Brembos are sitting on a shelf in the shed - if all they do is degrade heat dissipation and thereby bring on early brake fade, I'm not interested. FOR SALE: Genuine red plastic Brembo brake caliper covers.
Is there a catalog we can order from with images?No. 2,4 and 8. For dessert No. 9 pleaseAnd a video of the DRLs going to blinker for supper.
Quote from: tw2005 on March 18, 2019, 10:11:05Is there a catalog we can order from with images?No. 2,4 and 8. For dessert No. 9 pleaseAnd a video of the DRLs going to blinker for supper. I've got 2, 4 and 8's images scattered across either this forum or the FB page but here's 9: 3-Pin Electronic LED Adjustable Flasher Relay for Car Turn Signal Light Blinker 6913281753906 | eBay
They'd patch into the loom coming into the door, discretely under the bottom lip of the door trim, then use battery feed and door switch as the circuit.
Yes, Sir. The effect is to have the area below the door sill illuminate whenever the dome light goes on with door opening. Daytime illumination, while unnecessary, will go unnoticed.
Yes, all four doors but now you have me thinking. I have a few of those time delay relays, one of which can indeed tap the door unlock pulse and illuminate under the doors. That would indeed be more useful (thank you for the prompting).For exterior lighting that will withstand road exposure better (I think) I would source these instead of the strip lights, and use them as area spotlights.Protected by some simple plastic panelling just in from my side skirts, mounted on angle brackets and pointing back towards the rear wheels, one either side would be plenty: White 12V 10W Eagle Eye LED Daytime Running DRL Backup Light Car Auto Lamp Hot | eBayThoughts?
1.5A switched through a time delay relay and fed from a battery line? No drama.
So, ... If I'm going to tap into the signal that unlocks the doors and flashes the indicators, I'm going to have to study the appropriate schematic. Without one, the best I can identify is whatever line goes high or low to unlock a door, which TBH is all that's necessary.However, just to be able to choose an optimal tap location and save some time and effort doing continuity checks to identify loom pins, is there a schematic that might help?
Oh well, nice pair of LEDs I got in the postbut now I go to look underneath the car to find some way to run the cable from inside and I'm stumped. Not the success I was anticipating.
