Jerky acceleration
mat2219 · 20 · 18839
Offline mat2219
Hello everyone,
I just got a Hyundai i30 and it has an issue with acceleration.
In the morning  when i drive to work it accelerates as it should with no issues.
When i am leaving work it starts to accelerate erratically.  As i drive away it acts like i am  punching the gas pedal and letting off.  The effect is so much that people have  looked and likely wondered why i was driving that way. It seems to go away after about 3 to 4th gear. One day it did this issue slightly all the way home in all gears.
During this my foot is on the gas pedal and all else seems normal.
The car is a 2011 manual diesel with 150,000 km. I just took the car to get a fuel line cleaning and the fuel filter change thinking it could be that but its not helping.
I have connected a WOW odb computer and all systems from car pc are green with no failures.
Does anyone have any suggestions as to what might be causing this?
Thanks,
Mat
  • 2011 Hyundai i30 crdi 90 blue drive
 :welcome: Mat,
Sorry to hear that! I'm not one of the "tech heads" on here but it sounds like it's temperature related.
I can understand you also suspecting fuel filter/fuel line issues. Good to rule that out.
Hopefully our friendly helpful (more mechanically minded) members will help you narrow down the suspects.
If you have data record in the obd reader it might be good to record rail fuel pressure and throttle position and see how they behave when accelerating. There have been few times when people had got cracks in the fuel filter heater element. It has sucked air in causing drop n the fuel pressure.
I had issues with 3rd party filter. It was not flowing correctly and caused limp mode due low fuel pressure. Fixed it with OEM filter.
The rapid surging also has me thinking that your turbo boost is fluctuating.
A number of things can cause this, but a commonly hidden problem ( intermittent and temperature conscious) is a fractured hose going to the turbo actuator.
take engine top cover off and you will see them.
« Last Edit: May 14, 2019, 08:10:49 by nzenigma »
Offline mat2219
Thanks everyone for your leads. Yesterday i removed the fuel pump within the tank and found lots of gunk stuffing up the sieve so i was happy to get that all cleaned up.
I thought i would post these pictures for others wondering about the internal pump.
Ill dig deeper into the leads you have posted and when the solution is discovered, ill come back with a new post.
Could be a bit of diesel fuel bug there. I'd be adding a fuel bug additive. I don't know the best one, but someone will.  :cool:
https://www.google.com/search?q=diesel+fuel+bug+treatment&oq=Diesel+fuel+bug+&aqs=chrome.1.69i57j0l5.15059j0j8&sourceid=chrome&ie=UTF-8
No 'could be', it IS bug.
Curiously, we have recently been discussing the tank pump. Australian i30s dont have them.
But we do have the bug if it is a badly stored fuel supplier. Try to buy from a well used outlet.
You will see tiny jelly like creatures in your fuel if it is active. If so clean the tank out completely. Even if clean, treat new load of fuel with double dose of additive.
The one I use is Liqui Moly (for diesel fuel).
« Last Edit: May 14, 2019, 08:28:01 by nzenigma »
Shame about the issue, great images though. definitely will be more than cleaning just that filter, whole tank would be slimy I think
@mat2219
I Should have reminded you to replace your fuel filter. It will be full of gunk.
Offline mat2219
Hi, is the fuel filter heater element the black portion of the filter housing, just above the filter with a sensor wire?
Offline mat2219
Hey, I have replaced all of the fuel return hoses from injectors and also the one hose that goes to the turbo near the top. Is the actuator the round part that sits on top of the turbo?
The Turbo is variable vaned and the adjustment is via a vacuum canister and that hose is a vacuum hose.
Offline mat2219
Hey guys the mystery has been solved.
I tested the egr valve with a voltometer and found that it had a voltage rating that was low compared to what it should have been. I replaced it and now the car doesnt do the hestitation or hiccups anymore!
Hope this helps those who also experience this issue.
Cheers
Cheers
Excellent. Thanks heaps for getting back to us with an update.  :goodjob2: :goodjob:
Hope this helps those who also experience this issue.  :goodjob2: :goodjob2: :goodjob2: :goodjob2:
Cheers
 :thanx:  :whsaid:
The surging symptoms and evidence of bug did not lead me to think of EGR.   :-[
 Although, Im reasonably sure the fuel blockage did contribute.
I see this as another really valuable piece of information contributed by ( as usual) an i30 OWNER.  :wink:
Offline gtd2000
  • Tell it like it is...
      Within 12000 miles of Galashiels
Cheers
This seems to be a reasonably common issue with the sister model, the KIA Ceed.
I get the same symptoms starts and runs fine but if I do multiple starts that's when you get that "kangarooing".
Flooring the car solves the problem but cleaning/replacing the EGR valve seems to be the solution.
Was your EGR easy to change?
  • KIA Cee'd EcoDynamics
Offline AndreaACME
    • it Italy
      Milan
Hi everybody,
I have just bought a 2 year used i30 PDu ... and have the hesitation syndrome :(
1200-1250rpms  precisely (not kangaroo, just hesitation in that range)
It is more evident with increasing load or on steep hills but once over that rev range it is ok
The car only has 2000Km on the clock
  • 2017 PDE 5 Door Hatch, Diesel 1.6lt, Manual, Grey
Hi everybody,
Only done 1000km per year.  :faint: EGR problems are usually due to carbon/tar build up. If it is not en electronic failure, the EGR will be ok ( clean).
Sounds like the car needs an Italian style freeway drive  :happydance:.  Try Milan to Naples, then report back  :mrgreen:
Offline angel81
    • bg Bulgaria
      Plovdiv
Hi, I have similar hesitating problem with my 200 000 kms 2011 y - 1.6 crdi... During winter when motor starts at 1000RPM and above everything is fine, but when RPMs drop to point like 750-800 hesitation at accelerating and hiccups occur , mostly at 1 and 2 gear . Now when weather temperature rises the car starts close to 800 RPMs and driving gets dangerous at traffic lights, might hit someone if too close. Not sure if problem is temp related or RPMs related? Any idea what could be the reason?  Forgot to say .. computer diagnostics at HYUNDAI Dealer  said ALL IS FINE.
« Last Edit: April 14, 2020, 17:57:04 by angel81 »
  • i30 2011y, 1.6 crdi, 90hp, 6 gear manual, white.
