Tire Pressure
xlee11 · 5 · 5576
Offline xlee11
    • nz New Zealand
      Canterbury
I have a new Whitehawk that has Goodyear endurance tires. Trailer seems to pull and handle the road well.  Just checked tire pressure. The have 62 pounds of air in them cold. Max tire pressure on this tire is 65. Being at 62, is this an issue? Too low?  Thanks.
  • e46 330i
Umm? Wrong forim maybe?
This is a Hyundai i30 owner's club...
Whitehawk trailer?  :confused:
Offline xlee11
    • nz New Zealand
      Canterbury
Sorry, I have a Hyundai i30, just bought a Whitehawk, and try to get an answer by luck.
  • e46 330i
There doesn't seem to be a listing for those tyres in Australia or NZ. Is it possible the whole trailer is imported from the USA?
In any case,  I need more info.
As follows, from the tyre sidewall.
Size?
Load rating (load index)? Possibly (hopefully) Load Range D.
Is the trailer dual axle?
And is there a placard which shows the weight of the trailer?
I'm assuming they're LT (Light Truck) construction . Are you able to confirm that?
Size?
@xlee11
A couple pictures should speed things up
