I30 2008: unable to pull out the plug from the door lock actuator
Offline evimarn
    • mt Malta
      malta
Hi, trying to remove right hand door inner panel to remove window mechanism, but cannot for the life of me pull out the plug from the door lock actuator.Any help is much appreciated.thank you.Will post a pic of said plug.
« Last Edit: November 08, 2019, 13:36:47 by evimarn »
  • i30 2008 petrol
There's a tab on the other side of that bumpy bit to push but it's very difficult to get in there to depress. Otherwise you may have to go the long way and remove the external handle and unbolt the latchand pull that out with the inner panel as it sits on the clips attached to that panel. Inner edge of the door there's a plastic cap that reveals an 8mm bolt, that releases the end cap at the handle.
Offline evimarn
    • mt Malta
      malta
Thanks.
If it is the tab marked A it is really difficult to push, tried a flat blade and still will not give in.
  • i30 2008 petrol
The wimp aid
The wimp aid
Where does one place that fuel line to assist?
@nzenigma , stdby for incoming PM report on fuel lines :mrgreen:
The wimp aid
I was just trying to help  :rolleyes:  :rolleyes:
I first submitted that uniquely versatile  device 2 years ago; it has now been viewed 5,392 times.  :victory:
About that time the posts from the Poms became rather shrill, then ceased altogether.  :phone1:  ......Bliss   :twisted: :twisted: :twisted::mrgreen:
