lightbar switch - running cables through the firewall
seeds · 4 · 1967
Offline seeds
    • NSW 2880
has anyone passed wires thru firewall on fd my11 hatchback I want to install switch for a small lightbar
  • HYUNDIA I30 FD MY11 HATCHBACK 2.0L
No, I had a light bar but had it slaved to light functions available in the engine bay, so no need to deal with the firewall. :goodjob:
I snuck a cable through the rubber boot for the clutch cable at the firewall.
Used 20mm long about 8mm (old bit of pvc) hose, neat little cross cut, insert hose ,  insert wire, seal up around with silastic or similar, used bluetack to plug ends. If needed in future, pick out bluetack , pass wire & plug again .
Hope it helps.
PS- if yours is auto, could be a plate  where cable goes  :undecided:
  :goodjob2: My slave said no big deal too!
Now have hole in firewall
pic hosting website
