GD LED Light upgrade, help please?
kroner · 6 · 3368
Offline kroner
Hi All.
been browsing/searching and I found no list of the bulbs we have.
here's what I found so far.
apparently the running light/brake is a PY21 (warm white) with offset pins.
how about the rest? any recommendations?
thank you
  • 2012 GD Premium CRDI
Do you have an owners manual, they're all listed in there :)
Indicators should be PY21W/BAU15S - Amber :link: 1 x Canbus BRIGHT AMBER LED INDICATOR BULB No Hyperflash BAU15S PY21W ? Classic Car LEDs Ltd if you have amber side indicators in the front fenders they'll be T10
Park lights T10
Reverse lights T15 :link: 2X iJDM T10 T15 W5W 12V 20W CREE CANBUS LED HEADLIGHT SIDE LIGHT BULBS REVERSE | eBay
Head lights for both high and low should be H7 -2 pairs, unless your's are Xenon :undecided: these work well in the low beams on mine though I required bulb adaptors and rubber boots to extend the dust caps :link: JW Speaker H7 LED 6000K DIRECT FIT LED GLOBE - BUILT IN CANBUS pair 12-24V | eBay
My interior lights and boot are all these  :link: 2X iJDM 2018 12V 31MM FESTOON LED CAR UTE INTERIOR DOME MAP LIGHT BULB GLOBE BMW | eBay
« Last Edit: December 15, 2019, 04:26:33 by CraigB »
Here's an interesting idea when replacing with longer profile LED headlights:
Hyundai Ioniq headlight extended end cap
I wouldn't know whether it's a perfect match for an i30 but designing longer caps for other models wouldn't be difficult at all. :winker:
@The Gonz What I did in reply 219 :link: i30 PD active LED headlights to extend the caps was quite a simple procedure :goodjob2:
:victory:
Spotted those Philips LED T10s you used as parkers. Would you say they'd do OK as reversing lights? I've got some piddly cheapies in there temporarily while I shop around. At night the brake lights put out more light than the reverse lights for using the reversing cam! What specs are those T10s?
@The Gonz  No those bulbs are specifically for park lights, they're same size as normal halogen T10's with minimal light throw.
I use JDM T15 bulbs for reverse, same base as the T10 though the bulb itself is larger :link: 2X iJDM T10 T15 W5W 12V 20W CREE CANBUS LED HEADLIGHT SIDE LIGHT BULBS REVERSE | eBay
