Problems with my I30 not starting properly and cutting out in slow moving traffi
Offline green_giant91
      UK
I've been having problems with my i30 (2009) for the past 6 weeks.
It started with the car not taking longer to start and when it did start the ESP OFF light was on and the rev counter did not work. If i turned the engine off then on again the car worked fine. This would happen maybe once a week.
This week the car has cut out completely in slow moving traffic (in first gear and lots of stopping and starting) when i go to restart the engine I encounter the first problem. The car will take a min to turn on then the ESP light is on and no rev counter.
I have taken the car to three different mechanics but none can identify the issue. As it's an intermittent problem they will need to see the issue. I have read many forums online that point the finger at differen issues.
Has anyone encountered this issue with Hyundai i30, if so how did you solve this issue? I am worried the car may cut out when travelling at faster speeds.
  • i30
Hi GG  :wttc:
Did you try a quick search of our/your forum? Quite a few hits for your issue...
Here's the first I found:
:link: ESP Off light and rev counter disabled
First reading says crank sensor. Thanks Shambles  :goodjob2:
As the thread says, its a DIY job.
      UK
Yeh, I got the crankshaft sensor replaced yesterday. Fingers crossed this will solve the issue but I will only know for sure after driving it for a week or two.
Will update :)
  • i30
Fingers crossed  :fingers:
Quote from: green_giant91
The power of the web ...  :Cuppa:
Offline Kristinamarys
      Cheshire
Any update on this?  My 2009 does exactly the same - replaced the crankshaft sensor yesterday and now the check engine light is on and the car is very juddery when i'm driving.
  • I30 2009 1.4 Petrol Silver
Check light = code. What is it? My crystal ball cant read it!
      Cheshire
No need for Sarcasm, I intend to get a diagnostic done on it this weekend,  I was merely wondering whether the original poster had resolved the problem or whether they also were still having issues!  :disapp:
Offline Snookes
Sarcasm?  :disapp:  Madam you advised us in two separate threads that your MIL was on.  :phone1:  I was already involved in this thread. Both tw and I replied with the obvious;  YOU need to read the codes.
Welcome Kristina. That was how I ready your post. Quite frustrating having one problem fixed and another show. Up hope you can get to the bottom of it without too much grief or expense.
