Airbag light stays on
pidim · 18 · 13672
Offline pidim
Hi forum,
I notice today that my airbag light stays on. When I start the car all the lights go on as usual and they all turn off a after a second or two but then the airbag light comes back on and stays lit.
I tried disconnecting negative terminal on battery for 15mins as a first try but no change.
Is there anything else I can do myself as first step? Has this happened to anyone’s GD here and would this be a major issue?
 If there’s nothing simple, would this be a Hyundai dealer thing or could I take it to my independent guy?
Thanks again.
You're going to need a scan tool that can read the SRS codes, most basic ones can not and then once you have the codes commence fault finding from there, could be any part of the system
Offline pidim
Would I need to go to a Hyundai dealer or could my mechanic do it instead?
You would expect a decent workshop would have a scantool to access multiple manufacturers and systems. Find your favourite and ask the question prior to booking it in or find something online that could do it but probably just as cheap to get someone to scan in fact Supercheap offers this service if you just want to get a read.
I would say level 2  @ $28 but again ask the question before commiting.
:link: Supercheap Auto | Vehicle Health & Diagnostics
In depth scan of individual vehicle systems for more detailed reporting on engine fault codes
Reset of fault codes as required*
One complimentary follow up and system scan if required
Completed in 20-30 minutes
https://www.supercheapauto.com.au/on/demandware.static/-/Library-Sites-supercheap-shared-library/default/dwb9ea0b88/services/diagnostics/exampletest.pdf
Offline pidim
Thanks for the info.
Looking at the manual, it shows fuse #24 is a 15A specifically for the SRS control module. Do you think this could be a starting point?
Maybe, I don't have my manuals with me, I'd be more inclined to thing the fuse is fine since the system is generating a code.
When I got an airbag light issue on my 2014 GD I discovered the cable underneath the drivers seat was wobbly, possibly due to my constant readjusting of the seat on its rails. Part of the harness underneath the seat connects to the seatbelt switch which is an important feature of the airbag system, allegedly.
Offline pidim
Had car scanned today while I waited. Mechanic showed me the screen showing high electrical resistance from steering wheel and felt it would probably be clock spring with that reading.
Sounds expensive. ☹️
Nice, and good choice of action. No they are quite cheap maybe $70 genuine online, airbag and wheel will need to come off. Not a big job but clockspring needs to be centred correctly as there is a limited number sof turns it can handle internally before it binds up and snaps. Basically a long flexible tape conductor wound around a post.
There's a couple of types depending on whether you have cruise and vol controls.
Just realising this is GD, may only have one type fitted but design and principle will be the same
up until april 2014
934901W110
Offline pidim
Thanks for that.  I was quoted $368 incl labour to replace with a new one.
 :iws:
Hmmmm..The quote is a little bit up there , but not a Dealer style gouge.
No matter, you got advice from a mechanic and us for $0  :mrgreen:
« Last Edit: February 05, 2020, 05:05:51 by nzenigma »
As shambles says first check the connectors below the seats are home first, they can also cause high resistance faults to be triggered, and they are free to check.....
Offline pidim
Just finishing off that the job was done yesterday and issue rectified.  The invoice split showed the part as $150 and the rest was labour.  They gave me the old part in a plastic bag FWIW lol.
Thanks all for your help and was very useful to get all your background intel, as always.
was the part number i had correct? 150 is certainly better than 220. I  guess peace of mind getting sorted quick.  :goodjob2:
Offline pidim
Not sure actually, as I didn't end up taking it with me but looked identical to the image.
