i30 Hypermiling Techniques
Lorian · 118 · 42853
According to a search of our forums, Hypermiling is not a word that exists in the i30 community.
Not any longer!
Our cars are not hybrids, but there are a lot of things that can be of use from the Hypermiling community that can apply to i30 petrols and diesels.
So this thread is NOT to brag about how many MPG or LPK you get, it's to post advice and discussion on techniques that can help to attain these goals.
So I'll kick off with a few. I know some are obvious  :razz:
Parking
Where possible try to park facing downhill, and in spaces where you don't have to reverse in or out.
Driving
Don't brake. Well of course you are going to have to brake, but every time you do you are wasting energy and increasing your fuel consumption. Think ahead, get your foot of the gas sooner.
Slowing down
Remember the fuel pump cut-off. If you don't have a scanguage this is not obvious, but then you are decelerating don't dip the clutch and coast, keep the car in gear because the ECU turns off the fuel pump.
Offline Mutley
  • Woof!
  • Fiery Red 2019 Premium!
    • Mutley Productions
Parking
Why?
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
The petrol i30 can be driven extremely frugally around town.  It is possible to engage 5th gear from 30mph and the car will not shudder even as low as 25mph.  Change gear at 2-2500rpm in town also.
Offline whitbomb07
      Newcastle, Australia
Parking
Why?
So you don't have to fang the engine cold.
Not good for the engine, also when the engine's cold the engine uses more fuel.
If your facing down hill you can just coast (in gear) down, get a little bit of warmth and oil pressure up.
Regards
Daniel
Offline Mutley
  • Woof!
Parking
Why?
Regards
Daniel
Ahhh that makes sense. Thanks!
Btw you shouldn't use 5th gear at such low speeds as it makes the engine work harder.
Offline bumpkin
      Aberdeen
In 5th at 30mph the petrol i30 is quite happily sitting at 1500rpm, not a strain for the motor at all, unless you choose to try and floor it :)
In 4th gear at 30mph my car shows ~33mpg, in 5th this rises to ~38mpg.
Parking
Driving
Slowing down
Hey, great topic! Expect a lot of differing opinions...
I'll take exception to the idea that coasting (on the overrun) in gear is better than in neutral. Your point called: "Slowing down".
You need to consider whether the "engine braking" uses more energy than that saved from the zero fuel injection. I just love to coast down long hills in the reasonable belief that I'm saving fuel (apart from the quiet exhilaration ).
In practice, you need to evaluate (as best you can) which is the preferred way to progress WRT economy.
Given a very long descent I often observe a reduction of 0.1 l/100k before the bottom of the hill. I can't say I have repeated the experiment while maintaining 5th (top) gear.
If you really meant just while coasting to the lights. Then I take your point. :)
The best way to save fuel is ......................... don't turn the engine on  :lol: :lol:
Ask a mate for a lift :lol:
Hey Pip,
I get the same .1 improvement on descents maintaing 5th gear... :wink:
Of course when I said decelerating I meant when you need to go slower, If driving down a very long hill it only applies at the bottom unless its steep enough that acceleration due to gravity is higher than the retardation caused by the engine breaking. We have some of those in my part of the world, but not on my regular commutes.
Here's another, I call it floating the throttle. If you are driving along at a constant-ish speed, conciously try varying the thottle. You will find you can often back-off the throttle a mm or two, and not actually go any slower. This is particularly usefull when getting a partial tow* from a larger vehicle in front of you on a motorway (highway,freeway). If you have a good tow the effect can be very noticeable in the fuel economy. A scangauge is SO usefull for seeing this effect.
*I say partial tow as you always need to maintain a safe distance to the vehicle in front of course. In the UK this is generally accepted as being a 2 second gap. I only ever use vehicles I can see through for even a partial tow.
All good advice thanks Lorian...
Offline ch0pst1x
  • CRDi SLX
Slowing down
Unfortunately, i'm a noobie cake. As a result, I'm lost confused. This is apply only to slowing down from a hill or does this include slowing down into lights when you got your foot on the brake as well? Sorry, but could you explain this a bit more for me? =/ Sorry!
Slowing down
This refers to the ECU only feeding fuel to the engine when it requires it either to maintain idle or of course, when driving with accelerator pressed.
Whenever the car's motion is "pushing" the engine, no fuel will be used. This will occur when you fully release the accelerator whilst the car is in motion. No matter whether you are braking or not.
This will not occur when the car is in neutral (whether coasting or not) because it will then be idling.
Offline VatTas
    • lt Lithuania
      Lithuania
  • i30 1.6 CRDi BlueDrive
I wonder what is more efficient - driving in, e.g., 5th gear at ~1500rpm, or 4th gear at ~1900rpm (same speed).
In theory there shouldn't be any difference for fuel consumption, since in both cases you are moving the same mass having same overall resistance at the same speed.
But it's only when we do not take into account at what RPM engine is most effective.
If we are talking about 1.6 CRDI, I think that max torque is at ~1900. So it appears that it should be better to keep RPM close to this number (i.e. drive in 4th gear). But almost every "eco-driving" advice says "change gears as soon as possible". So I wonder if it's good advise...
I'd say change gear as soon as the revs are high enough that when you have changed up you still have 1500rpm. That way you don't bog down.
When chaging down its most efficent to do so sufficiently soon for the FCO to kick in.
6th is more efficient in practice, but only just, there isn't really a lot in it. I can easily* drive on the motorway in 5th and get really good mileage, and I don't drive slowly.
*After 20 years of driving a 5 speed sometimes I still forget to change up  :D
The RPM where the engine is most efficient will be masked by the turbo in the CRDi. You are correct that greatest efficiency occurs at max torque RPM but the "native" figure is being modified substantially by the feedback. So is the greatest efficiency at the final (system) max torque RPM or the original inherent figure?
That point aside, I suspect it is of lesser importance than your second point recommending running with the lowest revs (highest gear) for any given speed. Consider an extreme example of just how much extra accellerator, and therefore fuel, you need to rev the engine to say 4000RPM compared to idling, when the car is at a standstill. If this was not a consideration then most cars would not benefit from a 5th/6th gear because they usually can reach maximum speed in 4th anyway.
Lorian's advice to maintain the lower RPM at about 1500 when accellerating gently through the gears is sensible. This generally puts the change points between 2000 and 2500.
Offline VatTas
    • lt Lithuania
      Lithuania
Thats' what I usually do - let RPM climb to 2000-2500 then change gear.
Also, one more point - if you drive at low speed (e.g. 20km/h), overall resistance is rather small and there is very little difference in fuel consumption if you keep RPM at 1500 or at 2000 (not much power is required to move the car). But things change when speed goes up, as air resistance is function of speed v3. Much more power is required to move the car, so RPM starts to play bigger role - it becomes more efficient to drive at max torque RPM than below (i.e. you will consume more fuel driving 60km/h at 1500 than at 2000). With more gears it is easier to keep engine RPM in the optimal range, that's why 6-gear box is more fuel-efficient than 5.
For better fuel consumption, be careful where, when, how you use the Cruise Control.
CC doesn't think ahead for hills so it doddles along happily until the car starts to loose speed on the uphill and then slams down a gear or two in a mad dash to maintain the set speed.
I also suspect that the constant minor adjustments it makes on a straight flat road to maintain the speed would be causing throttle variances which would add to consumption.
I believe that a careful, forward thinking driver can operate much more fuel efficiently than a Cruise Control.
Having said all that, I am often happy to sacrifice any fuel saving for the benefits in staying under the speed limit and being able to devote my concentration to other things (like the idiots around me in the traffic and the road conditions).
Also, one more point - if you drive at low speed (e.g. 20km/h), overall resistance is rather small and there is very little difference in fuel consumption if you keep RPM at 1500 or at 2000 (not much power is required to move the car). But things change when speed goes up, as air resistance is function of speed v3. Much more power is required to move the car...
I think more correctly air-resistance varies with the square of the velocity, not cube. It is the power required to overcome that resistance that varies with the cube. So while air-resistance increases 4 times for a doubling of velocity, the power used increases 8 times. Why the power increase is double the air-resistance increase is because we will be covering the ground in half the time. Time is always in the power formula because power is the rate of doing work.
Not sure if I put that well but the bottom line is: If you double your cruising speed you use eight times the fuel all else being equal. Which does correspond to your V3 above. :wink:
Any physics teachers here? Feel free...
Offline VatTas
    • lt Lithuania
      Lithuania
Of course you are right. I was looking at the power equation, when I wrote this. Should be rephrased a little bit.
Offline agentr31
  • LOOK AT ME, LOOK AT ME!!!
lol we have uber fuel efficent cars... i think we are doing enough!
I remember thinking that in the 1960s when I was getting close to 30MPG out of a 1.6 litre Fiat!!
I'm glad we didn't stop there. :rolleyes: :lol:
Offline diablo
      Blackpool
My 1.4 petrol does a massive 31 around town, about the same as the cars I had 30 years ago.
My tip is not to slow down for bends.  8) Though it does wear out the tyres a bit.
Offline agentr31
lol you guys would have cried if you had my old car... roughly to a tank i was getting 600km and it had a 100L tank in it... just before it went to the wreckers it was playing up, and i was getting 20L/100km it was terrible! especially parting with the $130 to fill it :(
Offline Edition
Heres a question for you, when sitting in traffic, is it bad to just use the clutch to move along slowly? Does this put a lot of strain on the engine?
(Talking about the crdi here  :))
^-- that's what I do when needed, Eddy
Not sure whether anything is strained because of it tho
If you are slipping the clutch then it will be (slowly) wearing. In traffic I quite often drive using the anti-stall only to accelerate in 1st or 2nd gears (even 3rd/4th), and no clutch, where possible.
You have to watch out the i30's CRDi's torque doesn't give the car in front a kiss, it can be a suprising surge on the anti-stall sometimes.
Offline Edition
Yes I have noticed that Lorian, its a very powerful anti-stall! Did I read somewhere that you can get the garage to turn it off? (Not that I want to at the moment)
I don't believe it can be turned off. You get used to it  :D
