Broken parcel shelf strap knob peg
calvinnwq · 80 · 10399
Offline calvinnwq
      Sydney, Australia
The knob that holds the loop strap for the parcel shelf has broken off. First image is the broken knob, second is the good one on the other side.
Any ideas if this is replaceable? Couldn't figure out how to remove it or find this part.
Otherwise any suggestions?
  • i30 PD Active MY2018
 :whistler:
 :welcome: Calvin,
They are pretty strong, you were unlucky to break one.
Not sure how they secure but if nobody comes up  with a better idea I reckon my mate @The Gonz might be able to make somthing the right shape to fit over the remaining base.
He beat me!  :happydance:
The OPs pictures aren't showing for me.
But Gonzs is.
 :whistler:
Better make 2 so you can balance the red   :lol:
But Gonzs is.
Working for me. One is a picture of the normal log. The other shows the broken lug. Clean snap at the base so looks like a plug rather than a lug.
Offline calvinnwq
      Sydney, Australia
On the broken side, it looks like the end of a screw. I tried to hand twist the good side to see if I could simply unscrew it, but it didn't budge. Was afraid to use pliers to do it in case the good side snaps off too!
Good idea to 3D print, but don't have one at home. Might get a colleague to help. How would you recommend securing the printed knob on the broken side?
The Gonz has a 3D printer and an i30... if the replacement was designed to fit over the broken lug some Loctite 401 glue or similar.
But Gonzs is.
They work on my PC but not my tablet or phone.  :crazy1:
If anyone can identity the part online, I could try replicating the whole piece from the image.
Depending on the thickness behind the base, I'd be inclined to just try a self tapping screw.
Yeah. I know. Not the best looking solution but, failing all else, with a bit of black paint I doubt anyone would notice.
The bump posts by the taillights visible when you open the boot are probably a feasible replacement.
Offline calvinnwq
      Sydney, Australia
Have been trying to search the part but to no avail. Could only provide the picture of the non broken side. :(
I second that suggestion. I'm sure you'd be able to find one suitable in fact black ones like what come with mudflaps would already be close enough to the right colour and size.  If that worked you could snap the other one off and use two screws so they matched. You would be best to drill a pilot hole in the broken lug. You would risk the lug coming out when you drill the pilot hole but that would then solve your first dilemma. :goodjob:
Offline calvinnwq
      Sydney, Australia
I'll have a go again tomorrow at seeing if the good side can be unscrewed out. Otherwise I'll look at the self tapping screw option or finding something to glue over. Thanks!
Don't rush. Gonz will enjoy the challenge of making you something at an extremely reasonable cost. He is a good bloke (not putting him under pressure or anything)
..and talking of under pressure, if anyone can find the part number it is our guru Gerard @tw2005
I've retired from being helpful, I'm joining the dark side and going to be antagonistic from now on. Can't get any darn perts from O'seas and I have Rock Auto being deceptive to a question on freight. There is no economy air freight coming in.  That's from FEDEX, :crazy1: :crazy2:
P.S. Can you make 2 x friction plates and 2 x steel plates for a A5HF1 trans with these 3D thingies. @The Gonz
Is this on a PD that's under warranty?
817321K000TRY
Held on by a self tapper inside the trim
Offline calvinnwq
      Sydney, Australia
Still within the 5 year warranty. Not sure if the genuine part is a 12 month warranty.
Did you break it or did it fail? It should be covered except if you caused it to break, costs stuff all o'seas, I'd guess $8-11 here, hit the dealer up or wrecker but you'll likely get stuck with the whole trim so could be counter productive.
Offline calvinnwq
      Sydney, Australia
Car was bought used with it already broken unfortunately.
Bugger!
Think you're mistaken
sneaky, although it will be hard to justify failure.
:faint:
I'm picturing a rather elegant workaround:
- neatly drill through the centre of the broken base
- replicate a spacer that matches the healthy post's profile (3D printed of course!)
- use a self tapper in the new hole to hold the spacer in place
For this idea to take flight (mandatory air force reference) just post accurate measurements:
- upper (head) diameter
- lower (post) diameter
- head thickness and post height
- dimensions of the necessary self-tapping screw
I can use the image of the healthy one to use the measurements effectively and post a 3D file for you to give to your nearest printer, or we can determine postage cost (item manufacturing cost probably less than A$1).
___________________________________
However, googling the part number kindly supplied by tw, and his comment, I suspect the screw comes from inside, in which case you may need to remove the trim before you're able to remove the posts anyway. I that case, It will be simpler for me to design a whole new piece and you can use the screw that should already be there.
« Last Edit: April 08, 2020, 13:06:53 by The Gonz »
Offline calvinnwq
      Sydney, Australia
I'll report back tomorrow!
Never mind, Calvin, I have the design now, no need for specs:
This suggests it indeed fastens from within, so you'll need to get the trim off to replace it.
If you're keen on one, I can do it up this weekend in any colour you like as long as it is red, then you can paint it black or grey to suit.
Confirm with a few details (including diameter to check I have the right scale) in a PM and we can talk dollars cents. :goodjob:
