Help! My car wont start
Bedz · 10 · 7823
Offline Bedz
      Gwynedd
Hello hope you are well
I have a 2009 manual petrol i30
During lockdown the car was sitting for a few weeks and it seemed run out of battery. After successfully jumping the car and charging the battery (both with a looong drive and an overnight on a battery charger) now she wont start at all just turning over slowly.
The lights inside work as do the headlights so im guessing that the battery has charged. On the dash the esp off light is illuminated as is one of a car with a key inside.
Any help to get the car starting again would be amazing.
Thabk you
  • 2009 hyundai i30 petrol
Offline sundiz
      Helsinki
How old is the battery? Sounds like you need a new one. Older batteries often will not recover from draining empty. Might want to jump start it and drive it to a shop which can run battery test for you.
  • i30 cw 1.6crdi -08
When you turn the key does it make a clicking noise?
If so, then battery is dud.
But if you can get to garage or place that can test batteries get then to do a 'drop test' and that will give you a definitive answer.
Offline Bedz
      Gwynedd
No its a solid light
Offline Bedz
      Gwynedd
When i turn the key it sound like its turning over (not clicking)
Offline LesterPK
If you jump start it will it start?  If so probably still a battery issue.
  • 2009 FD cw Wagon, petrol 2L, Auto, White
Offline wbm00
      West Midlands, UK
If you keep the headlights on, do they go much dimmer when the starter motor engages?
Actually, mine (GD) switches off the headlights when the starter motor engages :head_knock: so maybe you could try this with the interior light on instead?
Most likely to be the battery if it's the original one from 2009.
Offline Covi30
      Mnt. Isa
Everytime my battery went flat, the esp light was on when i got it charged up.think it is normal.
  • 2010 i30 wagon diesel
Offline sundiz
      Helsinki
When system voltage drops, modern cars start to shut down non essential electrical stuff. ABS, ESP etc. often start to shut down (and illuminate error light). Different control units have different minimum voltage. It is also good to save electricity to mandatory stuff, not to leave you stranded. You still might be able to limp home without ESP and ABS... Many ESP and ABS faults are due low battery voltage.
