air horns are illegal in Victoria Ian,what about queensland mate. we can have an unroadworthy sticker put on our cars for using them. its stupid how easy you can buy things and fit them to your car to only find out the hard way they aren't legal,they shouldn't sell them if that's the case. IMO.
Are they one note or various sounds
And how many amps do they draw, more that 20A? Did you use the existing wiring, or did you incude a relay?
A quick search on google suggests they are legal if switched from a separate switch (in other words if your normal horn still works when you press the steering wheel button) but that is not an official answer - just from a couple of forums..
thanks for that!!!! much appreciated well in that case when i wash my car (this afternoon) i should take some pics for you
Hey. That's my ruler. Give it back dude!
HAHAHAHA a true fitter and turner never lends anyone his pocket ruler pics of where i installed the air horns as promised!!the horns are on this side of the battery mounted the the chassis rail there is an M6 tapped hole in the rail i simply made a bracket that holds the horns and bolts to the tapped hole (there are actually 2 holes from memory)so... hidden under the battery are the horns cant really see them LOLsame angle but as seen from just under the intercooler pipe with the radiator on the right hand side, engine on the leftnow for the pump... its mounted on the other side of the chassis rail off the inner fender there are 2 studs (M6 again) that i made a "U" shaped bracket off that holds the pump!you can just see the shiney silver top by the -tive battery terminalbit closer in with the battery on the left hand side, the front of the car at the bottom and the fender on the right hand side!as for the wiring, its simple it runs below attatched to the loom that runs to the factory horns and is zip tied to it, then i disconnected one horn, added some mini spade terminals to my wiring filed them down a touch (so they went into the factory plug) taped it all up so water cant get in the loom and bam working hornstook me a few hours to do because i had to figure out a good spot to mount them that was not noticable, then i had to get to the factory wiring from underneith the car... as that panel that runs arcoss the front of the radiator support panel is attatched to the bumper bar...
