The Fuel cap difficult to open
collin · 5 · 2038
Offline collin
    • nl Netherlands
      Waalwijk
The full cap  is difficult to open as shown on the link below:
:link: Fuel cap - i30 - YouTube
Is it possible to "adjust" the valve and if so how?
« Last Edit: August 24, 2020, 09:30:19 by The Gonz »
  • Hyundai i30
Offline sundiz
      Helsinki
Cleaning and lubricating the mechanism has worked well multiple times.
  • i30 cw 1.6crdi -08
Offline collin
    • nl Netherlands
      Waalwijk
Thank you,
But could you tell me were and how
  • Hyundai i30
Well, the release mechanism is obviously working as you can easily pry the flap open.
So clean & lubricate the hinge to start off with, then clean any gunk from around the release tab and try relocating the nylon cap tether.
Hi Collin,
It always helps to have more info in your vehicle decription in this case it may have helped to know if yours was a series 1 FD model as the plastic cap teather sometimes gets into a position in that model that can stop the cover from opening easily.
