2008 FD Cruise Control issue - Keeps speeding up.
Roubsan · 7 · 10279
Offline Roubsan
    • nl Netherlands
      Nederland
Hi guys. I'm having an issue with my cruise control. When engaged it keeps speeding up. For example when I set it to 100 kph it slightly accelerates to 105, 110 and so on. Even my cruise and set lights do not light up on my dashboard. I do have a little LED above my light adjuster switch on the left side of the dash (it's a LHD). This LED turns on green when the system is on and turn orange when a speed is set. It's really annoying I can't use the cruise control properly...
  • 2008, FD, CW, petrol 1.6l, Grey, StyleVersion
I wish I could help but I cannot be certain you have the same CC system as the Australian type and I have never heard of such a problem. :Dunno:
I no longer have this model either. As Gonz states, not a common issue. The only issue commonly reported on here with the Series 1 cruise is failure to set which is normally associated with a faulty brake light switch (a warranty repair on some FD's) This fault would be extremely unlikely to cause your issue.  :cool:
Fingers crossed some other member who has had your issue and cured it, sees this post. I'll amend your thread title to enhance the chances of a response.
RuudH
Hi Roubsan,
Do you have a John Gold aftermarket cruise control [AP500]?
Offline Roubsan
    • nl Netherlands
      Nederland
It is a John Gold system yes.
Offline need4speed
    • de Germany
Hello,
if the cruise control in a hyundai i30 is not working, it most likely means a faulty brake switch or speed sensor issue. You should let that check.
Martin
  • i30
