Idle problems
Erik62 · 7 · 10845
Offline Erik62
    • se Sweden
      Stockholm
It's a i30 FD 2008 89kw (122hp) petrol
The car runs well but stops at idle.
No problem when I drive but stop at every traffic light. No problem to start over and drive away but very annoying.
It goes bad before it stops.
Error codes says:
P0016
Crankshaft position -Camshaft position
correlation (Bank 1 sensor a (Intake))
P0172
System too rich (Bank 1)
  • i30 fd 1,6 petrolium 122hp
Offline Covi30
      Mnt. Isa
do search here,
well covered by past advisors
  • 2010 i30 wagon diesel
Offline Greyhound
Offline Erik62
    • se Sweden
      Stockholm
I think it gets too much petrol.
Cold it starts easily. Warm, it is more difficult to start. And then it goes badly at idle.
But it responds directly to the accelerator pedal and runs perfectly on country road driving.
Stops at every traffic light and it smells catalyst.
Cam, Crank correlation if it is wrong, can it then go perfectly except at idle? I have looked at the cam chain and it is possible to pull up and down about 5 millimeters between the camshafts, I do not know if it is too much. I have measured the crankshaft sensor and there is nothing wrong with it (860 Ω). Camshaft sensor I can not measure.
Offline Covi30
      Mnt. Isa
clue: what makes the cam position change? keep searching
Offline Erik62
    • se Sweden
      Stockholm
New tensioner and chain solved the problem.
Thanks!
Offline Covi30
      Mnt. Isa
Thanks!
to help the site's lost or non-existant technical advisors,  :faint: :faint: cam position is an oil pressure related valve , easily changed and clean associated filter,
AND the FD does NOT have a chain.
