Noise from aux belt
Syco · 4 · 1847
Offline Syco
      Camberley
Hi, got a 2015 G4LC i30, It's been making a horrible noise from the aux belt. Running the car briefly with the belt off and the noise is gone. I took the water pump off and it's fine and replaced the idler puller and noise is still there. Cars only got 50k on it but thinking it might be the alternator.
Whats got me puzzled is it's a 7 vee pulley and belt, everything I see online is for a 6 or 5 vee belt.
Am I missing something? Is this unique as it's right on the model transition?
Any one replace the alternator bearings on one of these?
TIA
  • 2015 i30 Hatch
Hi Syco (great name!)   :wlcome01:
Quote from: Syco
Paste your vin into :link: PartSouq Auto Parts Around the World and see if there's any enlightenment there, regarding the vee configuration.
Offline Greyhound
The type of noise is not mentioned. If the belt is squeeling then is the belt itself old, shiny and slipping?
Once upon a time you could get "belt feed" spray to recondition slipping belts.
  • i30 PD 2020 1.0 T-GDi
Offline Pnut
    • nz New Zealand
      Auckland
Did you replace the belt? Its usually the cheapest fix, assuming you mean 50k miles then its had a good run.
  • Sold - 2011 FD 5 Door Petrol 1.6 Auto Red
