Air Conditioning
Mike SX · 23 · 6915
Offline Mike SX
      Essex
Does anyone know whether the output of the A/C differs in hotter/cooler climates than the UK.
In the present temperatures of approx. 30 deg. cent. the i30 (& the Wife's i20) are not particularly cold, compared to our other UK vehicles.
If so, would it be either the refrigerant, compressor power or condenser, etc. :neutral:
Mine's not particularly cold either, but is a dammed site better than when I'd just had it "fixed" :rolleyes: (I think I had a blockage in the drier/evaporator which has suddenly cleared itself).
Here's a great quote from HonestJohn
The two main causes of failure are lack of gas (via leaks at the system seals) and component breakdown. Low refrigerant means low lubricant, which is contained in the refrigerant, and this can lead to seals drying out, thus losing even more refrigerant and leading to failure of the compressor.
Here's another great quote from the same webpage:
With a standard manually controlled a/c system you should leave the a/c on all the time, even if not using it to cool the car. You should also turn the system to full cold for ten minutes once a week – even through the winter if you can – in order to circulate refrigerant which contains lubricants for the system and its seals. Then switch to full heat through the same pipes to thoroughly dry them out. This gets rid of any moisture in the ventilation trunking where mould and bacteria might be accumulating.
Climate control systems, where the temperature is set by the operator should be left on all the time, as the a/c will be required to fine tune a reduction in temperature. The vehicle will decide for itself whether to engage the compressor or open the outside flaps and let in the outside air, which at 0 - 3c Celsius will have no moisture content anyway.
Offline Mike SX
      Essex
I don't think the black interior helps..... :P
Mine is pretty cold. Driving back from silverstone it said 26-28c outside, but I had to have the temperature up about 5 or 6 clicks not to be freezing with my (manual) aircon on.
Offline Mike SX
      Essex
That sounds pretty good, I set mine as cold as it will go.... It would be even warmer if the car had more passengers.
When we got home my Wife sat in the sun to warm up, I went and had a cold shower :wink:
Maybe it's just me, but I felt a lot cooler, and quickly in the XJ8.
It feeezes my hands really quickly, due to my hands always being directly in-line with the vents. Bit of poor design there.
I don't think it cools my feet very well when its set to blow downwards too.
My aircon is really effective.. provided you cool the interior of the car down a bit by driving with all 4 windows open for a few seconds after parking in the hot sun.. :D
i also do this and it works a treat,also I've found the air is a lot colder if its on recirculate and not on fresh.  :razz:
I dont use recirculate often, but am sure it would get way to cold then.
Don't forget a little boost to you aircon, if you don't have drinks in the glove compartment switch the aircon off in there.
yes, but it also lets in hot air when the heater is on.  :eek:
Offline agentr31
  • LOOK AT ME, LOOK AT ME!!!
warm beer for the poms!!! :)
i forgot about that.  :eek:
Offline agentr31
Offline Mike SX
      Essex
I've tried it all, to no avail, so to give the aircon "a good start", I had better get my garage airconned :rolleyes:
I wonder how the aircon copes with 5 up in hot climate, i.e. regular 40/50 degrees.
The i20 is a even worse.
I think most "Poms" prefer cold beer. Especially as we are getting a climate to rival Australia!
Most pubs you go into nowadays here usually have "extra cold" offerings
Offline agentr31
LOL extra cold aye 18oC?
nah im kidding man i know you guys (and girls) dont drink luke warm beer!!
It is quite strange because on the couple of days I have driven in 38c heat since I got my CRDi the Air Con was faultless .. :cool:
Offline agentr31
mine is freezing... but i havent owned long or driven it on a truley hot day yet...
Checked mine this am.
Outside was showing as 16 C
Inside. well frost appeared on the window screen   :lol: :lol:
ps was Cold, very cold!
Offline Mike SX
      Essex
19 deg. outside. Stood XJ8 and i30 together, ran engiines for 10 mins both with air con on, used a digital temp. gauge directly on face vent output. (& drawing air in).
Results: XJ8 4 deg. & i30 6 deg. XJ8 can frost up the windscreen at 25 deg. i30 cannot :P
Offline bumpkin
  • Keeping it in the family!
      Aberdeen
Yep, mine goes very cold too, usually accompanied by Kim reaching for the temp dial :rolleyes: :rolleyes: :rolleyes:
"But darling you look fine to me" :wink: :wink: :lol:
Offline Mike SX
      Essex
I must have been medically re-formatted (acclimatised) at Echt & Sullom Voe, never needed aircon 'til then......
Offline bumpkin
      Aberdeen
 :lol: :lol:  Yep, you know what I mean when I have a chortle at the ozzies complaining about 12C being cold, it's midsummer here and today it's 13C, sheer luxury :lol: :lol:
