Crankshaft Position Sensor - 08 i30 CRDi
Offline JLang83
      Worcestershire
Hi All
Hoping for some advice - car wouldn't start and AA came out - machine reader said crankshaft position sensor issue. Garage replaced this but no joy - engine still intermittently fails or won't start. Mechanic says it could be related to the flywheel - repairs for this would basically write-off the car. Can anyone think of another reason the CPS replacement hasn't solved the error?
Grateful for anything at all!
TIA
  • 2008 i30
Hi there JLang83 and  :welcum:
Did your mechanic recalibrate the system with the new CPS fitted? I'm fairly sure this is mandatory...
Offline JLang83
      Worcestershire
Thanks Shambles. I'll ask tomorrow - can you explain what you mean by this?! I'm totally illiterate about car mechanics!
  • 2008 i30
A decent mech would know if this is required - usually involves some driving at set speeds. One of our Tech Advisors might know more.
Offline JLang83
      Worcestershire
Ah - the car still wont start or rather mostly wont start - occasional burst of life. Something is interrupting the signal and making the ECM think the sensor has failed I think?
  • 2008 i30
I did a quick search in HY repair manual and did not find any mention about calibration after change. Coil resistance of the sensor should be 774-946ohms and signal waveform should be checked with a scantool after change. Recommended to check with camshaft position sensor to see that camshaft position sensor has one signal and crankshaft has two in the same time period.
