pip & baradeur 100%I think the future will be in LED lighting. Almost indestructible, very low voltage & power requirements, selectable light output K. I have them at home in our standard lamps for room lighting, they use a whole 5 watts, I have more on order. I forecast within 2 years there will be an effective automotive equivalent.
Quote from: 847563 on May 22, 2012, 01:24:03 pip & baradeur 100%I think the future will be in LED lighting. Almost indestructible, very low voltage & power requirements, selectable light output K. I have them at home in our standard lamps for room lighting, they use a whole 5 watts, I have more on order. I forecast within 2 years there will be an effective automotive equivalent.In fact that is slightly incorrect. As you know LEDs have been around for ages as tail lights. We have all seen how prone they are to failing in the old spoiler stop lights.Luckily today's LEDs are a generation past that and can be expected to last much longer. LEDs are far from indestructible. In fact, the worst enemy for them is heat. On of the major reasons holding them back from incorporation in headlights is that to produce the light output needed, they generate a great deal of heat and unless you can dissipate that effectively, they will cook themselves and self destruct. In fact I had read that some Audi models and the highest spec Prius may have them as headlights, if not here, overseas.
Well, I had one of my Osram Night Breaker Plus H7 globes blow yesterday....
Dammit crappy poo bum. left side headlight blew this morning!
Good news with the new model i30.....From my observations today I reckon globes will be able to be changed without removing the headlight assembly....
Quote from: rustynutz on June 07, 2012, 05:44:17Good news with the new model i30.....From my observations today I reckon globes will be able to be changed without removing the headlight assembly.... Nice bit of observation Rusty
I must admit I haven't paid a lot of attention to this thread in the past but I've been driving my wife's Corolla a fair bit in the last couple of weeks and some of it at night. It's a 2005 model and hasn't yet had a bulb blow.My i30 is coming up to 3 years old in November and has done a fair bit of night driving back from Brisbane after work and is yet to blow a bulb.Sure I know all 4 headlight bulbs will blow within a day of my posting this but is it a diesl only phenomenon? I remember some discussion about spikes when starting. Does anyone with petrol model have problems?
Just a reminder that some of the headlight globes that are blowing are aftermarket globes. These do have a shorter life than the standard issue globes.
I was running Osram Nightbreaker Plus on my CRDI and got somewhere between 6000 and 8000 km's from them. It's because of the DRL, the caralso runs with a high voltage(14.2 v) on the bulbs that does't exectly extend their lives
I added an extra earth cable of decent size from Negative battery terminal to the gearbox side of the top starter motor mounting bolt... .. At the headlight assembly plugs I joined the two black wires together and added to them another 5mm wire which I earthed on one of the two panel bolts behind the headlight just below fuse box. I also fitted a 3 amp blocking diode between the Low beam wire and the earth in reverse... ..We shall wait and see.
