Squeak/squeal- bearings?
Npmr · 3 · 9252
Offline Npmr
Hi
I would really appreciate any help or advice on this...
My UK 2016 i30  makes a squeaking/squealing sound as the wheels rotate but only after driving for some time eg 1/2 hour,  and after coming down a very steep hill! It usually persists for some time after this.
I have had brakes and pads replaced but it was there before and after this work, although it is slightly higher-pitched now and appears more noticeable when reversing. I had taken the car in to the dealer but they couldn't find anything obvious and the sound wasn't there when they had the car.
 I have tried to video it and you can hear the sound -kind of chirping in forwards and more metallic in reverse (although slightly muffled by the ambient sounds of driving with the windows open)- YouTube links:
It doesn't seem to change when braking so I think its something to do with the wheels/rotation/bearings...
Any ideas and thoughts of how to confirm what the issue is?
many thanks
Offline Npmr
* update!
After driving for a few hundred miles more I can say that the noise does seem to stop when the brakes are used, even lightly.
Offline sundiz
      Helsinki
Tried to listen videos, but my audio or my hearing is so bad that I did not hear a thing. If possible lift one corner up and try to wiggle the lifted tyre.
  • i30 cw 1.6crdi -08
