wiring
paul · 10 · 2597
Offline paul
      Brighton
does anyone know if the i30 diesel has canbus wiring??
Offline Myowni30
  • Midlands, UK
I don't think the i30's use multiplexed wiring systems at all.
It does have a can bus, thats what the odb2 port allows out scanguages to connect too. I haven't looked in detail what is and isn't on the canbus, but you'd be able to find out by looking at the wirining diagrams for the elantra touring on www.hmaservice.com
Offline paul
      Brighton
hi lorian it wont let me have an account on  www.hmaservice.com
is there a uk version ?
Offline Myowni30
  • Midlands, UK
What happens when you try to Sign UP  :question:
I've signed up and all you do is log on with your password
And the information is only freely available on that us site.
Offline paul
      Brighton
it wont accept my zip code(post code in uk)
and the link to the terms of use comes up as a blank page
"HMAService Privacy Policy and Usage Agreement Link
 Problem with the above link? See NOTE below:
NOTE: If your computer has Windows XP operating system, you may have an automatic
Pop-up Blocker running which can prevent these links from opening. To bypass the Pop-up
Blocker, hold the "Ctrl" key (lower left corner of keyboard) while you click on the link, and
do not release the "Ctrl" key until the download window fully appears.
Also, I note that the BBC's postcode W1A 4WW seems to work just fine.
Regards,
..and the link to the terms of use comes up as a blank page
That happened to me with Firefox, swapped to IE and it worked fine. You do need to tick a checkbox on that page.
