Front electric windows on 16 plate I 30
Offline Searley10
      Kent
My front passenger window will go down from the switch but won’t go back up ,although the drivers side can make it go up and down with no issues any help or ideas please ,thanks
  • I 30 blue
 :wttc:
Sounds like the passenger door switch needs some TLC ;)
 :whsaid:
If one switch works and the other doesn't, look at the switch not working.
In auto electrics, the most probable cause of trouble is the mechanical aspect, as in the non-solid-state electronics.
Start with getting the switch off and check for good clean contact. Depending on your abilities, it's either a bit of polishing or replacement.
Is it still in warranty or upto 6 months out, understand extended for covid, then get dealer to check and fix.
Offline Pnut
    • nz New Zealand
      Auckland
This is what i did to fix mine, a good blast around with electrical contact cleaner and it came right.
  • 2011 FD 5 Door Petrol 1.6 Auto Red
