Washer reservoir and lines clogged with algae
Offline ryangus
Had my 2017 PD in for a 60,000km service yesterday.  Have noticed for a while the windscreen washer wasn't working, and the dealer has diagnosed it as algae in the reservoir blocking the lines.  $270 to remove and flush.  Hopefully this a simple DIY job for someone handy with tools.  Any suggestions, and procedure for removal and flushing?
  • 2007 SLX CRDi
Check if there are any blowback valves on the line, remove hoses from them and push pressurized air in to the pipes towards reservoir. Drain and clean reservoir and fill it with good guality washer fluid.
Online Aye30
Hi, was the dealer removing old fluid and refilling the reservoir on your dealer services? They used to on our fd. It used to annoy me as I used quality additives which worked better than the dealer stuff. But given the amount of clogged washer fluid lines/ filters I read on the forums, I now know why the used to do it. Check the pd log book service descriptions. I wouldn't expect there to be a problem, if they were flushing the fluid every service.
If I had to clean out the system i would get access to the reservoir via the front wheel arch (FD) disconnect the pump lines and push air backwards through the system. Inside the reservoir there is a small filter before the pump, which is usually the first to block up. Sometimes a jet of water into the reservoir can dislodge the scum. I DIY'd some plumbing fittings, taking mains hose pressure down to water filter diameter, crimped the end a bit with heat to make a spray that went perpendicular. I stuck that into the reservoir and blasted away at the filter area. I had a manageble flow out of the top and watched as chunks came away from inside the tank. I was lucky that the algee had not progressed into the lines.
Few posts on here as to how to clean the tank and lines.
It's a diy job so keep your $$ in your pocket.
Offline BrendanP
      East Midlands
I've always used screenwash and never had a problem. I have had friends that just used plain water, or added eco-friendly dish-washing liquid. In a Rover 75, the contents of the reservoir turned into a thick gloopy jelly. Pulled the pump off and let it slowly ooze out, then flushed the tank clean with hot water.
  • i30 CRD
Offline Greyhound
...or added eco-friendly dish-washing liquid.
Doesn't most dish washing detergent include salt. Advised not to use it to shampoo the car with it for that reason.
  • i30 PD 2020 1.0 T-GDi
