2011 CW 93kW engine cover replacement
Offline giwi342
    • ee Estonia
Hi, this is my first post here and it's about a small problem I've made.
I was trying to replace the ignition coils on my i30CW 2011 1.6 93kW engine and managed to break the screw hole so I can not secure the coil any longer. Is there anything I could do except to buy a 100€+ cover from somewhere?
At least I think it's called an engine cover..
  • 2011 5 Door Vagon, Petrol 1.6lt 93kW, manual
Mine's Diesel and I think yours is petrol so I'm having trouble relating to how a healthy post would look in that picture. Is there value in just using the holes to insert a thinner bolt and nut with washers to sandwich the whole thing back into shape?
OK, I just watched a video on coil removal. You say you might have to buy a new cover that hosts that post. If so, that suggests you can remove it and perhaps drill through the bottom to accommodate the above suggestion.
Offline giwi342
    • ee Estonia
Thank you for your reply.
Yes, mine's petrol. sorry for not specifying.
I am attaching a picture of the non-broken part.
I am not sure what are you suggesting? I doubt the coil cover will press hard enough on them for the coils not to move around.
« Last Edit: November 28, 2021, 09:31:40 by Shambles »
OK, so what I'm suggesting, short of buying another cover, is that you
1. remove the damaged cover
2. grind/sand the broken post flat
3. insert a resonably flat or countersunk headed bolt with a large flat washer from below the hole
4. use the bolt as the new post, adding washers and a nut from above as needed
